Pritchard- after rereading your posts i'd try to determine the true nature of your problem. when it acts up again, with the engine running unplug the spark plug wires one at a time to see which ones make the engine slow down or have no effect. if there is no effect, check for spark at the plug. if there is spark, then switch the injector plugs temporarily to see if it moves the problem to another cylinder. at least you'll know whether it's a fuel problem or a spark problem and can proceed from there. and if it's in a paired pattern of 1/4 or 2/3 then that's another clue.
Bleyseng- the one that's on the car i can't read the number but it's a 72 1.7, so it's probably the 049 mps. can i adjust out the wot setting to correct it, or should i look for a different mps?
How much do you want for the Throttle body?
PD
72 914 2056: 74 9146 2.2: 76 914 2.0
