Proprietoristicly Refined
You put in a 90 degree adapter-----WHY? The '88 924S does not need it if OEM (if not modified somehow). MY low side is on the firewall passenger side.
I do not have any trouble getting the hoses to the lines. (The early 944s required the 90 degree under the compressor for access--fyi)
When you put in the 90 degree adapter, did you first remove the origninal schroeder valve before you put on a 90 degree adaper with a 2nd schroeder valve? The new 90 degree adaper may not depress the OEM schroeder valve.
Another guess may be a clogged expansion valve.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
