I would guess that adding hard lines will add 4 more connections as you would need to transition from hard line to flex to the component connection for vibration resistance.
4 more connections on a system that already looks like an old school piping screensaver is probably not a good thing.
There would be less resistance per foot of run but would be another target for the uninformed putting the car on a lift.
The suction hard line would need to be insulated so as not to add more heat that is not doing any work in the system.
Bill K.
