View Single Post
stomachmonkey stomachmonkey is offline
The Unsettler
stomachmonkey's Avatar
Why Toilets Are Still Made of Porcelain
A toilet needs to do three things well, according to Brian Hedlund, Kohler's senior product manager for toilets. First, "It needs to be a flushing engine." Next, he says, "It needs to be water-proof, clean, and sanitary." Finally, explains Kohler's king of thrones, "it needs to be sturdy." Because people sit on it. Some of those people will be quite heavy. Porcelain, as it turns out, aces at all three of these requirements.
Most important to the user is that the toilet be an effective, ahem, waste remover. But what looks to most of us like some water swirling down a hole to who-knows-where is actually a machine with a pretty complicated design. "The tank, bowl, jetway, trapway—it's highly detailed," says Hedlund. "There's a lot of intricate engineering." Vitreous china toilets (what we call porcelain) are made from clay and water. The manufacturing process, which includes being poured into a mold, finished, glazed, and then sent through a kiln, is pretty straightforward and fairly inexpensive.
Plastic, on the other hand, is formed into objects via extrusion or injection molding. For a structure as complicated as the toilet, plastic manufacturing is prohibitively expensive. That's why plastic's presence on the throne is typically confined to the seat; it's just too expensive to have a leading role.
Another factor is durability. Let's face it, we've all needed to haul ass to the toilet—and when that happens, the thing better damn sure not give way beneith us. Vitreous china is super strong and highly rigid. Plastic, though, has some give. While it likely won't buckle under the weight of a hard landing, it certainly might feel that way, and the way it feels matters to users.
Ok, so maybe plastic isn't practical. What about stainless steel? It's strong and easy to manufacture. Hell, they have steel toilets in jail, right... The problem, it seems, is user experience. While stainless steel is super sturdy, it's also really sensitive to temperature changes. In other words, it will freeze your ass. Topping it with a plastic or wood seat just doesn't look right, and prison chic doesn't go very far in the average home.
Porcelain is also a champ at shrugging off water. It may sound simple, but a porous material will allow liquid and bacteria in, so being impervious to both is important in a structure that's main job is to deal with waste. The key to keeping water out is in the porcelain's glaze. After the toilet is coated, it's fired in a kiln. Unlike, say, grout in a shower, which takes on both water and bacteria, the glaze stops bacteria at the toilet's surface.
"I want my two dollars"
"Brandon Won"
Old 02-15-2015, 08:25 PM
