View Single Post
Wyvern Wyvern is offline
Wyvern's Avatar
Help with IPD / codes / smog please
Hello .
2006 Cayman S, K&N, Aftermarket exhaust...
Installed a IPD plenum and 82mm TB.
I was throwing a P1095 code so purchased a MAF.
Still toss the code every now and then.
Check / rechecked install and am confident with the install.
So I clear it using my Scangauge.
Today went to smog it and no code but the other sensors came up "Not ready"
So need to drive work through the drive cycle.
If I do that the code most probably will come back and and I now can't clear it or same issue and I cant just leave it ???
My first thought is that I have a bad MAF
Second thought is to just, reinstall all stock TB and Plenum and leave it if this is going to continue ..
Any thoughts ?
Brian
Old 01-26-2016, 01:56 PM
