-   -   Guess dyno result & your own 3.0SC boosted build results (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1000117-guess-dyno-result-your-own-3-0sc-boosted-build-results.html)
gavinc69 06-20-2018 01:05 PM
I've been on this forum for many years now and in that time seen quite a few 3.0SC engines get boosted. Results have varied from 300hp to over 400hp.
I have just had the results from my final dyno tune and would really appreciate those that have boosted there 3.0SC engines your input as to what dyno figures you achieved and with what mods as I feel my results are a bit on the low side for the mods I have done :(
Also have a guess at my final dyno figure based on the engine spec below :
1980 3.0SC euro engine (rebuilt to standard spec apart from following)
993 headstuds
993 cam
Port and polished heads
RS cut valves
With tweaked CIS and no turbo was making 230hp crank.
Added later :
3.2 intake manifold
Full bay IC (specialist custom built, light weight, high flow)
Tial 46mm WG with 0.5bar spring
OBX headers
K27-7200
BOV to atmosphere
Omex 710 ECU with coil packs
Going Super Fast trigger wheel kit
Siemens Deka 80lb injectors
Zork tube
Tippy 06-20-2018 01:10 PM
A 3.2 AFAIK stock is supposed to make 350 flywheel hp at 0.5 bar, so I'm going to guess 310-320 or 270-280 whp???
Tippy 06-20-2018 01:11 PM
Just turn up the boost and fahgetaboudit!!!
puddy 06-21-2018 05:05 AM
Interesting. Would your smaller displacement be affecting things a bit?
flat6pilot 06-21-2018 07:15 PM
370whp
scottrx7tt 06-23-2018 05:56 AM
I made just over 400hp in my old car at .8 bar. Ran e85 and a large intercooler. K27-7200 hi flow turbo
flat6pilot 06-26-2018 02:24 PM
So what were the results, Gavin?
Geronimo 09-22-2018 05:00 PM
How fresh are the engines you guys are slapping turbos on? I am soooo tempted to add boost.
flat6pilot 09-25-2018 02:54 PM
I added mine 2 years ago with 180k.
Uncle 09-25-2018 03:42 PM
I dunno if I’d read too much into numbers. I’ve seen a fair disparity between U.S dyno and Australian dyno results for example.
If the motor is doing the right thing and AFR's etc are all good then I be happy.
gavinc69 09-26-2018 01:39 PM
Dyno result was 320 crank. After gearbox rebuild may try 0.7bar
Tippy 09-26-2018 02:21 PM
Do I win a prize? ;)
