Upgrade to modern relays?
I have upgraded my fuse box to a modern blade style with classic retrofit.
Now I’m wondering can you upgrade the relays to modern ones so I don’t have to worry about Chinese knock off garbage
2016 Alfa Romeo 4C 1982 911 turbo 2018 Mclaren 720S |
I'm sure you can - my EFI is using newer style relays and mounts in the engine bay. You will need to rip and replace, or leave in place and add to all the existing mounts I suspect ... not sure if anyone offers a ready made solution. May want to contact TurboKraft and ask them - they seem to be on top of all trends related to more reliability and performance.
I think just upgrading the fuel pump circuits and the various overboost and ignition relays, etc. would be all you need to do, maybe. You should just save up and swap it all for EFI
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
hi
i also had many problems with the OEM relay and fuse. so i built a new style relay and fuses on the old bracket. it looks nice and the most important thing is that it works like a new car.
no more turning to fuse in the middle of the night on a dark road |
I looked into similar ones but they weren't rated high enough for some of the bigger fuses. |
Some information about those fuse blocks would be great. I upgraded to the classic retrofit ATO fuse panel and it’s a night and day difference. I stopped getting tach bounce and the relay for the headlights made mine so much brighter.
James 1989 Slate Grey 930...sold ![]() Looking for the next one! |
My interpretation:
![]() I used TE Connectivity VCF4-1002 sockets. They dovetail together to form the block. You have to buy the terminals separately. https://www.digikey.com/product-detail/en/te-connectivity-potter-brumfield-relays/VCF4-1002/PB714-ND/813781 The relays are Panasonic CB1a-R-12V sealed automotive 40 A with the resistor buffer. An excellent, high quality relay, probably better than any stocker, and the price is right in quantities of 10. https://www.digikey.com/products/en?keywords=CB1a-R-12V
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
![]() We are looking at a plug and play relay solution for the original round relay sockets.
www.classicretrofit.com |
When? I love your stuff. Thanks for shipping out the alternator so quick. It’s installed but won’t be tested until Monday
I never had tach bounce, but the headlights (Euro H4s, stock bulbs) were very noticeably both considerably brighter and cast a whiter light after the Classic Retrofit fuse panel fitted. Came in very handy when caught in a snap arctic storm and had to drive through 60+ miles of black ice - you could actually see when road surface in the tire tracks changed from wet slush to "uh-oh, that's just shiny, not wet"...
'77 S with '78 930 power and a few other things. |
Take a look at this. Its draft right now, I am working on a design to print this in 2 materials with a ABS body and a TPU or some other flexible material surround.
https://www.tinkercad.com/things/64kXy9EsMmX-porsche-911-relay-adapter/editv2 |
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
I have the Classic Retrofit fuse blocks fitted. They are very nice. I still don't have many miles on the Turbo as I am away with work. Since I am stuck in Spain its not all bad!
More than the fuses I really hate the relays. For me the issue is that they are now all made in China and the quality is not as good the OEM ones. I carry spares everywhere! |
