-   -   Alternator problem. (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1007908-alternator-problem.html)
quattrorunner 09-15-2018 12:53 PM
Alternator problem.
So my new alternator works great. I changed it and now the alternator lights stays on and engine also. Somewhere along the line I’ve screwed up. The engine idnition won’t switch off. I have to remove the fuse to the ecu and disconnect the battery. The alternator light stays on. Charging fine. Which wire got cut or screwed up? Installed exactly as it had been.
quattrorunner 09-15-2018 03:04 PM
Never mind it’s sorted itself out? Odd
mark houghton 09-15-2018 05:46 PM
Well now. that's comforting :confused:
quattrorunner 09-15-2018 05:50 PM
Right?
Speedy Squirrel 09-16-2018 06:11 AM
You didn’t replace the external regulator alternator with an internal regulator alternator by any chance?
quattrorunner 09-16-2018 07:06 AM
Well not this time. The one I replaced was same type but it was new to the car which before that had an external.
