-   -   930 header opins needed. (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1010288-930-header-opins-needed.html)
quattrorunner 10-14-2018 09:00 AM
My China headers are cracking. I have a support for the waste gate pipe broken at the #1 header pipe. (Actually I welded it last night) Also have had boost creep because of the bad design for the wastegate pipe. Had considered going back to the euro Porsche exhaust heat exchangers. I have all the parts still but thought I should ask others their opinions.
The boost creep is because of a gt35r that boosts quite well.
Also I have efi and stuff if that helps. Seeing 1.4 bar with a 1 bar spring. Should I work on the wastegate circuit or change over to the euro headers?
Thoughts please thanks.
Tippy 10-14-2018 10:07 AM
Don’t know about the Euro stuff, but heating the welds after repair to relieve stresses may prevent future cracking, or at least prolong life
boosted79 10-14-2018 12:41 PM
This is what you need to do to cure the cracking. It puts the stress from the WG into the flange instead of the primary wall. The boost creep can be fixed by running an add'l tube from each secondary at the elbow where it turns up into the turbo into the elephant trunk.
http://forums.pelicanparts.com/uploa...1539544433.jpg
http://forums.pelicanparts.com/uploa...1539546008.jpg
Blaine Sellie 10-14-2018 01:05 PM
I'll soon be selling my used B&B headers w/heat, drip tank, oil lines, etc... If you are interested let me know.
Blaine
puddy 10-14-2018 03:46 PM
Why not get a set of badass RarlyL8 headers?
quattrorunner 10-14-2018 04:39 PM
Because I usually like to spend way more money wasting time and efforts Before getting the goods I should have in the first place.
RarlyL8 10-14-2018 05:22 PM
HA!
Unfortunately you are correct, nomatter what you do those headers are going to crack again. The cheap alloy used will simply fall apart with heat cycles. I've seen them come off in pieces after one track event. We have turbo systems that have been on the track for 10 years with no cracking, way past typical header life span for that environment. Ours were designed to address all the issues I had with typical short tube 304 stainless headers when I built the Red Rocket. Material we use is 321 stainless. The primaries and secondaries are equal length, F1 collectors are internally polished, waste gate circuit comes off both banks at a better angle to avoid boost creep. The latest version has welded collectors, v-bands for easier installation and optional welded heat exchangers. We had to re-fixture to do these things but the results were worth it. The sound this tuned system makes is like no other.
http://forums.pelicanparts.com/uploa...1539562464.JPG
pkabush 10-14-2018 05:26 PM
Hard to beat B&B for design and efficiency. Chris at Turbocraft has done quite a bit of testing and the dyno results speak. I have two sets both of which were bought used for around $600. One with heat one w/o. Ive also had a set of Brian’s headers and not only do they sound amazing but they’re automotive artwork. Good luck with whatever path you choose.
pkabush 10-14-2018 05:28 PM
Looks like I was beat to the punch. Nice pix.
1979-930 10-14-2018 07:33 PM
GT35R twin scroll set up with Brian’s headers. I get compliments every time I drive it on how amazing it sounds.
https://uploads.tapatalk-cdn.com/201...ea0baffe2d.jpg
https://uploads.tapatalk-cdn.com/201...e3782b6643.jpg
quattrorunner 10-14-2018 07:46 PM
Good grief that’s sexy.
1979-930 10-14-2018 10:04 PM
Thank You. I like the black ceramic coating.
The exhaust pipe below the rocker is camouflaged better. I like to hide things that don’t complement the body lines.
Midlife930 10-15-2018 04:44 AM
My system from Brian has been solid from day one. Put it on a fresh engine, that went 5 track seasons before a refresh and is now ending the second season on that refreshed engine and still strong with no issues.
Dave
with my buddy Charlie in the M3 at Watkins Glen
http://forums.pelicanparts.com/uploa...1539603570.jpg
quattrorunner 10-15-2018 12:06 PM
I've had these in use since 2012 and haven't had issue till now.....
The past couple weeks I've had an overboost condition that has put extra strain on them but overall they've been better than expected.
What I'd like to know right now is weather the euro heat exchangers might serve me nearly as well (power delivery)as these if I fix these.
RarlyL8 10-16-2018 07:07 AM
The Euro exchangers and J-pipe are better than the USA system but still underperform when compared to any sort of header. Yes fixing what you have will buy you some time and definitely out perform the J-pipe setup. Be sure to check the new welds on the inside for slag and grind it off if you find any.
boosted79 10-16-2018 07:26 AM
Do you have heater boxes? The bare ones like mine are much less trouble than the boxed ones because there are a lot fewer welds to crack. If I want to take my car for a ride in cold weather here I put a coat on.
Alexm930 10-16-2018 07:41 AM
I can not say enough good things about Brian's Headers. Spend the extra money now & avoid all the headaches.http://forums.pelicanparts.com/uploa...1539700870.jpg
timc 10-16-2018 08:01 AM
I'd call/talk to Chris at TurboKraft as well, you want as much practical knowledge as possible...at least I would.
tim
Tippy 10-16-2018 08:40 AM
Fix your Chineses headers, rosebud the welds, carry on.... ;)
JH282 10-16-2018 01:16 PM
Did you open up/remove material where the waste gate tube meets the manifold?
http://forums.pelicanparts.com/uploa...1539720930.jpg
quattrorunner 10-16-2018 01:35 PM
Yuk no but I intend too
gavinc69 10-21-2018 02:51 PM
That's my OBX headers, readily badly made waste gate feed but once cleaned up works a treat with no boost creep at all now.
Defiantly worth checking this location on your headers.
ChrisD87 10-23-2018 05:27 PM
I have a set of like new b&b's without heat and for sale if ever you want to go that route. 800$ plus ship
VZ935 10-25-2018 10:20 AM
I just use that 40 year old factory stuff
http://forums.pelicanparts.com/uploa...1540487855.jpg
quattrorunner 10-25-2018 10:32 AM
My headers are holding .6-.7 bar max on a .5 bar spring. I think the heavy spring was just larger than I need.
Carbster09 11-05-2018 08:13 PM
1979-930, what a great looking car! What tires are those? They just look nasty. Is your car in Texas? I just moved to Houston, 930 on the way in a week or so! Just in time for some nicer weather!
1979-930 11-05-2018 08:48 PM
Thank You. It's in CA. TX is a Vacation/Rental.
The tires are Nitto NT05's 255/40-17 Ft and 315/35-17 Re on Fiske 17x9 and 17x11.
I hope you don't mind humidity. Your 930 is going to need some serious AC mods!
Pat RUFBTR 11-06-2018 10:19 AM
To maneuver with 255 it is not too difficult? :)
reclino 11-07-2018 06:09 PM
That 40 year old factory stuff looks sweet. I need more Inconel in my 930!!!
