-   -   911 Turbo conversion: Turbo return line filter? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1021086-911-turbo-conversion-turbo-return-line-filter.html)
baloo 02-14-2019 02:53 PM
1987 911 3.2 turbo lo-boost conversion, with TurboWerx electric scavenge pump.
Been reading that coke chunks can fly from the turbo and go into the return line and into sump drain.
Any thoughts about an in-line mesh filter?
There's a -8AN 150u mesh filter on EBAY (https://www.ebay.com/itm/8AN-Male-To-8AN-Female-High-Flow-Billet-Turbo-Oil-Feed-Line-Filter-80-Micron/192587432061?hash=item2cd71b007d:g:CD0AAOSw4shX-foo:rk:17:pf:0
See pic.
150u too big?
Or how about a catch can with a filter inside - screw-in cannister with filter element?
Too much bother?
http://forums.pelicanparts.com/uploa...1550184652.jpg
1979-930 02-14-2019 03:47 PM
It's worth doing something. That oil should be filtered before heading into the engine.
I install a XRP space saver inline filter in the return line with a 10 micron screen. It was too small and restricted the oil flow too much. The pressure caused leaks.
I call XRP and switched to a 40 micron and it has worked just fine. I have no idea what 150u equates to in microns. But $9.00 Lunch costs more. Get something better.
Page 46. Pt# 704406FS40
https://www.xrp.com/wp-content/uploads/2013/12/XRP-new-Product-Catalog.pdf
baloo 02-14-2019 04:02 PM
Derrick, thanks.
(150u is my way of saying 150 microns)
Have you had to empty the filter yet?
Don't know how much particulate a turbo would produce.
Wonder about a cannister with removeable element might act as a catch can as well as large capacity filter?
Rawknees'Turbo 02-14-2019 04:24 PM
Originally Posted by baloo (Post 10355749)
Derrick, thanks.
It really only produces particulate (coke particles) if the oil has a too low flashpoint and then cokes in the turbocharger axle/bearing housing after engine shutdown - a high flashpoint synthetic (most, if not all of them have high flashpoints, relative to dino oils), and allowing the engine to idle a little bit (a minute or so - or simply a slow, short cruise as you reach wherever you're going) prior to turning it off helps a lot.
moty 02-15-2019 12:04 AM
Hello
I made 2 years ago the same conversion with 3.6 and i use TurboWerx electric scavenge pump in the car since the engine is 1990 N/A i had to use the electric pump - however there is a problem i had damage 3 turbo on the way in the past 2 years all the turbo had major leaks of oil in to the inlet - the turbo oil seals where damage - the bearings and the shaft is fine only the seals - my turbo repair guy told me it only because of the pump he says that it is too strong and in idle it sucks all the oil, from the shaft and there for the seals are damage and breached out . it is possible ? is he right ? can you help me and take me a picture from car regarding the oil return to the engine with the pump.
any help will be appreciate.
thank you
T77911S 02-15-2019 04:21 AM
what he said along with dirty oil.
this is why a syn oil with a little less zinc than a dyno oil is much better for your engine. shutting down a very hot engine is very bad as he said.
the bad thing about that filter is if it gets clogged your turbo is toast, although better than the engine.
you want the oil to goto the sump, then it gets filtered. one mod is to reroute the outlet of the scavenge pump into the top of the breather cover, the other is directly into the sump through the drain plug.
baloo 02-15-2019 05:29 AM
Originally Posted by moty (Post 10356111)
Hello
...my turbo repair guy told me it only because of the pump he says that it is too strong and in idle it sucks all the oil, from the shaft and there for the seals are damage and breached out . it is possible ? ...
I do not know.
I would think the oil feed would send oil around the bearing first, before hitting the return port.
I'm trying to imagine the oil possibly taking a direct route from the feeder line directly to the bearings, then without covering the bearing, going directly to the return line?
Wish I knew.
However, many Pelicaners have used the TurboWerx scavenge pump, and I can't recall see ing them complain about a similar problem -- ALTHOUGH it is possible that they did not think of this as a cause of their turbo failure?
Dunno.
'76 911S 3.0 02-15-2019 08:34 AM
I had a similar issue Moty described when I had the pump connected directly to the drain without a reservoir. I ended up making a reservoir with an atmospheric vent to my intake piping and the problem went away (you can see in this photo here, the grey canister):
http://forums.pelicanparts.com/uploa...1550248433.jpg
Regarding a filter, I have the Turbowerx filter pre-pump and the pump returns to the breather cover on the top of the engine.
baloo 02-15-2019 09:54 AM
Jayson,
Good info, thanks.
1) So you drained to the breather cover and not the sump plate?
2) How often do you check your pre-pump filter for clogging?
'76 911S 3.0 02-15-2019 10:47 AM
Originally Posted by baloo (Post 10356487)
Jayson,
Good info, thanks.
Yes drain to the breather cover, not the sump plate:
http://forums.pelicanparts.com/uploa...1550256400.JPG
I haven't check the filter yet, I am currently rebuilding the engine for a second time due to a mishap of my own accord, unrelated to the turbo. The filter is stainless and has a magnet element in it to catch any metallic debris that may pass through it.
mark houghton 02-15-2019 05:40 PM
Spend a little time searching this topic; it's been covered more than once over the years. Here's a link to one discussion and application that may be of some use.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/458520-black-granules-my-oil-help-2.html
Ken911 02-18-2019 06:21 AM
you know thw stock turbo sump has a strainer in it. I dont understand why none of the replacement sumps manufactured for headers dont also contain one.
