-   -   ignition timing turbo engine (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1023834-ignition-timing-turbo-engine.html)
turbo930ss 03-17-2019 04:18 AM
Hi
Looking for some information on what people run for ignition timing on turbo engines.
I have a 3.3 turbo motor running twin plug with 8:1 compression. This is a race engine running 110 fuel.
thanks
Scott
philip j 03-17-2019 01:47 PM
EFI or CIS ? engine management? need more info on your build...
s5uewf 03-17-2019 03:05 PM
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/500986-ultimate-930-distributor-advance-retard-timing-turbo-lag-msd-mod-thread.html
turbo930ss 03-19-2019 02:37 PM
Thanks for the link.
It's AEM infinity ECU, twin plug, coil on plug, two knock sensors, 3.2l intake, gt35 turbo, sc cams, .8 bar boost for now.
Scott
s5uewf 03-21-2019 04:40 AM
Here is another link with some tables to help get you started:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1017181-how-calculate-base-ignition-table.html
Every engine with mods is slightly different it seems, so you will need to find a way to get on a dyno or similar and tune WOT runs to maximize your curve for that high octane, without introducing knock. I do not think many of us run with 110 octane. I know that is why I cannot really help you. I run 93 octane.
flightlead404 03-21-2019 07:17 AM
My approach, detailed in the second thread linked was to calculate the stock curve, figure out where the peaks and valleys are, and build a table that approximated the stock curve. That s/b enough to start, do checkouts, and get it to a dyno tuner.
That's my plan anyway
