930 wont start no spark
Is there a thread somewhere I can follow to check the ignition sequence? I have fuel and both pumps running.
So your fuel pumps are working. Both of them? have you checked specifically that there's no spark? No spark to any plug could point to the CDI. Are you hearing a high pitched whine with the key on?
I went through this myself, finally getting the car started. Here's what I had to do: * Replace the fuel ( car was sitting for quite a while ) * replace the fuel tank ( rust! ) * Checked system pressure it was good * checked spark ( no spark to any plug ) * replaced spark plugs ( I don't think I needed to do this ) * rebuilt CDI ( mine wasn't whining, so no spark ) Try this as well: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/547032-sticky-common-answers-why-my-car-doesnt-start.html |
I have to power to terminal 15 on my Bosch CDI box. Trying to trace it back and see where it is interrupted? My factory shop manual references a different wiring diagram
| All times are GMT -8. The time now is 11:16 PM. |
