-   -   These are my injector fuel flows - should I try and adjust? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1028426-these-my-injector-fuel-flows-should-i-try-adjust.html)
flightlead404 05-02-2019 04:09 PM
These are the fuel flows for each cylinder, approx 30 seconds (time doesn't really matter its the relative differences I'm asking about). This is at the fuel line, no injectors.
Cylinder Light Mid Full
1 89ml 138ml 218ml
2 89 133 200
3 89 131 210
4 90 141 223
5 81 135 208
6 85 135 200
Should I bother to attempt to adjust these? A shade less than 10% diff low to high at full throttle.
flightlead404 05-02-2019 04:29 PM
Interestingly I did the same set of tests with the injectors on and the flows were leveled out. For all intents and purposes putting the injectors on the fuel line made the flows identical cyl to cyl across the board.
I think the fuel lines need a little back pressure to accurately compare the fuel flows.
So, I guess it's moot.
Alan L 05-02-2019 05:38 PM
They are 'OK'. Nothing serious. But when you think 930 on boost and maybe running close to the line AFR wise, 10% is quite a difference. I get mine to 3%. After that it is luck as to how well they come out, and how long I can persevere. But my beast spends most of its time on WOT. The simplest one would be to dial 1&4 back a bit (below the #3 reading). I only worry about the WOT readings - I try to get these as close as I can.
Alan
Alan L 05-02-2019 05:47 PM
To save you looking the info up, you would back the adjustment screws in #1&4 off to reduce flow.
I would take them back approx 1/4 turn for a start. That should get you close.
Alan
flightlead404 05-02-2019 07:33 PM
Alan
Thanks Alan.
Turns out the flows are identical with the injectors on the end of the fuel line, so I'm not going to fool with it.
Alan L 05-02-2019 08:14 PM
I mis read you. Thought they were the same ........... as the original readings.
Alan
flightlead404 05-03-2019 06:33 AM
Alan
Fixed it, thanks.
Pesch 05-03-2019 07:14 AM
Hello,
When you mention Full, is that at full stroke of the metering plate?
I get quite uneven and bad repeatability at full stroke.
While at low and intermediates strokes I managed to get things even.
Alan L 05-03-2019 01:10 PM
Pesch -You could be running out of fuel. best check fuel supply.
Alan
flightlead404 05-03-2019 02:11 PM
Originally Posted by Pesch (Post 10446746)
Hello,
I tested by pressing down the metering plate. While I tried to be consistent with how far I pressed down, and how long I held, I didn't stress too much because what I was concerned about was all injectors being the same at whatever given deflection.
I did tests with about 10-15% of deflection for "light", about 50% for "mid" and all the way down for "full".
Now, to your point, I don't really know if the airflow metering plate ever actually gets depressed all the way down. It would be interesting to know that for certain. I'm guessing that even at full throttle, down low, on a cold day (i.e. maximum density air) you are aren't at the limits of travel on the arm.
Pesch 05-03-2019 02:35 PM
After struggling to get even flow at full swing of the metering plate, I get uneven flow at inermediate opening...
Then remembered this post http://forums.pelicanparts.com/6626613-post12.html
And decided to set even flow at 37mm stroke, then checked at 25mm and 10mm all was consistent.
