These are my injector fuel flows - should I try and adjust?
These are the fuel flows for each cylinder, approx 30 seconds (time doesn't really matter its the relative differences I'm asking about). This is at the fuel line, no injectors.
Cylinder Light Mid Full
1 89ml 138ml 218ml
2 89 133 200
3 89 131 210
4 90 141 223
5 81 135 208
6 85 135 200
Should I bother to attempt to adjust these? A shade less than 10% diff low to high at full throttle.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 05-02-2019, 04:09 PM
Interestingly I did the same set of tests with the injectors on and the flows were leveled out. For all intents and purposes putting the injectors on the fuel line made the flows identical cyl to cyl across the board.
I think the fuel lines need a little back pressure to accurately compare the fuel flows.
So, I guess it's moot.
Old 05-02-2019, 04:29 PM
Alan L's Avatar
They are 'OK'. Nothing serious. But when you think 930 on boost and maybe running close to the line AFR wise, 10% is quite a difference. I get mine to 3%. After that it is luck as to how well they come out, and how long I can persevere. But my beast spends most of its time on WOT. The simplest one would be to dial 1&4 back a bit (below the #3 reading). I only worry about the WOT readings - I try to get these as close as I can.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-02-2019, 05:38 PM
Alan L's Avatar
To save you looking the info up, you would back the adjustment screws in #1&4 off to reduce flow.
I would take them back approx 1/4 turn for a start. That should get you close.
Alan
Old 05-02-2019, 05:47 PM
Alan
Thanks Alan.
Turns out the flows are identical with the injectors on the end of the fuel line, so I'm not going to fool with it.
Old 05-02-2019, 07:33 PM
Alan L's Avatar
I mis read you. Thought they were the same ........... as the original readings.
Alan
Old 05-02-2019, 08:14 PM
Alan
Fixed it, thanks.
Old 05-03-2019, 06:33 AM
Hello,
When you mention Full, is that at full stroke of the metering plate?
I get quite uneven and bad repeatability at full stroke.
While at low and intermediates strokes I managed to get things even.
Many projects on the way...
1987 930 Road trip car (1/2 owned)
1982 DP935 future beast
1969 911T rust bucket
1966 911 Buffum college car (1/2 owned)
Old 05-03-2019, 07:14 AM
Alan L's Avatar
Pesch -You could be running out of fuel. best check fuel supply.
Alan
Old 05-03-2019, 01:10 PM
Originally Posted by Pesch View Post
Hello,
I tested by pressing down the metering plate. While I tried to be consistent with how far I pressed down, and how long I held, I didn't stress too much because what I was concerned about was all injectors being the same at whatever given deflection.
I did tests with about 10-15% of deflection for "light", about 50% for "mid" and all the way down for "full".
Now, to your point, I don't really know if the airflow metering plate ever actually gets depressed all the way down. It would be interesting to know that for certain. I'm guessing that even at full throttle, down low, on a cold day (i.e. maximum density air) you are aren't at the limits of travel on the arm.
Old 05-03-2019, 02:11 PM
After struggling to get even flow at full swing of the metering plate, I get uneven flow at inermediate opening...
Then remembered this post Information about the 934 CIS Injection
And decided to set even flow at 37mm stroke, then checked at 25mm and 10mm all was consistent.
Old 05-03-2019, 02:35 PM
