BTW, he has a Matt Monson differential in that thing. PS - this is also some more inspiration for Geronimo! :D <iframe width="839" height="559" src="https://www.youtube.com/embed/0CwlJaeKQ_k" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
Rawks, is that the one that used to do wheel stands at the drag?
My car is nothing special, and will never be stock, that just isn't my style. I have a picture in my head of what I want, (sadly a few pictures but one car). I think the best plan is to sort a solid base parts list and start looking for deals on the parts as they come and shoot for a solid low boost set up with future potential. And pray I find a future trans solution lol. |
I'll bet! Its hard to tell from the pics (gorgeous) but are the two airflow paths entirely separate, ie that intercooler is really two-in-one, or does the airflow merge after the turbos? If merging, are the two turbos the same, or is one build to build pressure earlier and one to deliver more air later? |
My cup of tea is a modded engine built by the Special Wishes Department, the original factory power kit...the 930 WLS http://forums.pelicanparts.com/uploa...1560782370.jpg |
I would have like to have had a 930, but they were just too expensive. I found an awesome deal on my car, a 79 widebody conversion that needed a lot of love, a non runner. it was as bastardized as it comes. 3.1(yes, factory 3.1)with 3.2 heads and a custom intake that used a Holley Pro-Jection TBi setup. The ecu was burned up, along with a lot of cut wires. I ditched all of that stuff and sourced a 3.2 intake, fuel rails, and throttle body. I used a Bitz ecu(MS1) to run it all.
The one thing that always bothered me is the TURBO emblem on the rear lid. Either I take it off, risking paint damage, or add a turbo kit. I chose the Turbo route! I can never leave anything alone! I sourced most all of my parts used. It takes some time to find things at the right price. This was the age where 930s were so hot, that pretty much anything turbo related had elevated asking prices. you really have to do your homework, but take your time sourcing parts, and build it when you get them all. I did my conversion in a weekend, also added EDIS ignition, and Microsquirt ecu. I have far less in my car than a 930, it will embarrass any stock 930, and will impress a lot of folks out on the roads. If my car were a 930, I would be more worried about my investment, but since i have one of the most bastardized cars on the market, Im not worried about it. |
same for me. got the project not running. had a rebuilt 3.3 turbo motor but 74 mag case 915 with 7:34 and other gear changes best for a NA on autocross, then a TALL 5th. now that I have a proper 930 gearbox I have most of what I need. of course waiting on parts I sent to Shaun at tru-6.com to cerakote and replate, along with the stuff I sent to Steve Weiner at Rennsport Systems to build / recondition. yesterday started restoring the rear light housings. and need to finalize my wiring plan so Dennis can build the full, customer wiring harness.... over 5 yrs but think I can see it starting to come together. now to get the tub on the rotisserie and get busy with finalizing the body work and prep for paint. and when done I do expect it to significantly out preform any stock'ish 930. I am into the wrenching and ultimately the DRIVING experience, and not the 'investment' angle or garage queen show cars. gotta drive them. and for the 1,000+ hp junkies, at least they dont hang a set of balls off the rear bumper as I see on so many trucks.:eek: |
OP, exactly how much is the all in budget ? |
I am not sure on the budget... as much as I can get by the wife yearly... lol she is very cool.
I figure the turbo set up should cost me $5k - $8K give or take. maybe $10K when all in said and done, IE tuning and lil bits and the unknowns. If I can get ll the bits in the next two years I think that would be reasonable and might keep me under her "want to punch my face radar". |
If i'm smart I start doing some art side hustle to make some Porsche play money, and put that fancy degree to good use.
By the time all was said and done I spent enough on this car to buy TWO 930's at the time (before the recession). It would involve great difficulty and expense to build this car starting with a 930 instead of the stripped down base model SC that was used. The value of the 930 would be reduced in the process while the value of the SC would at least stay the same if not increase a little.
In the end this car was crazy fun. 915 5spd with 360whp, 2700lb with me in it. 0-100-0 in 13 seconds. After 15 years of enjoyment I sold it to buy a 930. 930 is a COMPLETELY different car / experience and fun in a different way. Do what you want, there is no telling what the future holds. http://forums.pelicanparts.com/uploa...1560809255.jpg |
i passed on a few 930's because i did not find them as agile as my SC. ended up doing 3.6 in the SC instead.
found the low comp, long 4 speed great for motorway but not tight corners or local race tracks. ended up with a 964 turbo as well though, g50 five speed and coil overs from factory. |
I have far less than $5k in my turbo set up. In fact, I’m gonna guarantee i have less than that even in my EFI and turbo set up combined. Obviously, I did all of the wrench work. Maybe if you are paying someone to do all the work, I could see $5-8k. My engine is still high compression, but I have my car set up for flex fuel, but currently on 93 pump gas and no problems at 10lbs of boost. Until the next transmission explosion, that is.
Hey man, I love what you are doing! I have a lot of friends with Supras, one with just over 1000hp. It’s crazy that you could achieve the same success with an air cooled engine. I bet it wasn’t cheap. Hell, running that fast in the mile is awesome, but it would scare the **** out of me. There have been some serious accidents the past year, including a fatality in Florida at a half mile event. I worry about how fast some of these streetcars have become just over the past few years. Be safe man! If I had the cash to put into my car to achieve what you have, I’d be right behind you brother.
Love the 964 look, if I didn’t have side vents, I would love to do the update. The side vents have kind of grown on me though.
But like you said, definitely an each to their own scenario. Quote:
Rarelyl8 that is a sick sick car man.
I may start a thread at some point to help me create a parts list specific for my needs so I can keep an eye out for deals. I know one of the turbo guys did a nice spreadsheet of parts and costs. I did pick up a 3.2 intake manifold, fuel rails, and TB. |
I quite agree, there is no way that car has 1200hp.
That color car is only good for a max of about 750hp! |
I'm probably in the minority here but I just like the look of a 930. I prefer a normally aspirated air cooled engine. I've already had a real 930 and one that was highly modified with 3.5L, K29 turbo, and a ton of engine mods getting it close to 400HP. It had suspension mods to match. It was fun, but I cannot say it was any more fun than my stock 996turbo. So for me it was an easy decision to go with modifying my 75 911s rather than pay the money for a real 930 again. I'll find out in the next month if I made the right choice. I'm hoping the 3.6L 964 engine with Motec engine management and Rasant Engineering intake is going to breathe enough new life in to the car to make it feel fast and fun. It will have ~280HP and still doesn't weigh very much despite the wider fenders and heavier engine.
http://forums.pelicanparts.com/uploa...1560841902.jpg http://forums.pelicanparts.com/uploa...1560841957.jpg |
| All times are GMT -8. The time now is 10:18 AM. |
