Thoughts or advice on turbo
Hiya,
I have a '84 ROW 930 with some of Brian Bodart's finest parts on it. Headers, TiaL wastegate, street muffler, and (I believe) the 7200 turbo. I started to notice smoke regularly on startups. I've had the valve guides recently redone - so I suspected the turbo. And... It's the turbo. So off it comes to be sent out to be rebuilt.
But,
Before I do that, what say the forum: rebuild or go to a different/better turbo?
Those are the only mods on the engine and it's strictly a road car. Can I do better with a different turbo? Also using the downtime opportunity to swap out the factory shift assembly and (possibly) upgrade to a WEVO.
What does the forum think?
Old 06-14-2019, 10:45 AM
Just rebuild that 7200. Send it to evergreen turbo in FL. I've had mine done there as well as others. You will not be disappointed. Yes you can do a better turbo.. but probably not worth the money. You can get upgraded turbines within the turbo as well if you desire for faster spool ext.. The turbo will come back looking factory fresh :]
https://www.evergreenturbo.com/
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 06-14-2019, 11:18 AM
Crotchety Old Bastard
RarlyL8's Avatar
If your going to the trouble and expense of a rebuild have Charlie add his latest power mod. He's done a few for me and wow do they wake up the K27-7200! Threshold stays the same but it pulls harder and longer. Worth the money IMO.
Old 06-14-2019, 07:53 PM
Brando
quattrorunner's Avatar
I agree. If rebuilding add some upgrades. And also look at the price of new borg Warner turbos or something like that before spending on the rebuild, maybe worth it to just replace. Keep the original tho
Turbo powa!
1977 911s. it's cool
Old 06-16-2019, 06:30 PM
