Crazy WBO2 Install Behaviors - Please Help
Before I lose my mind completely!
After a run of bad computers and bad sensors, that may have masked this issue or this issue may have lead me to believe sensors and computers were bad that weren't I FINALLY have this behavior nailed down and it is a head scratcher.
I have a known and verified good controller (ALM-INLINE) and known good, and tested Bosch LS4.9. Both of these devices are good, and work together......most of the time.
When I say they work correctly, I see the linear output voltage from the controller behave as expected.
Whether running on ships power or on an isolated power supply the behavior is the same. When I power on the controller/sensor I get a 20 second delay at around 0v output (normal voltage) then:
-In free air it goes to 5v - normal for this controller
-If I use an unlit propane torch to pass gas () over the sensor the voltage drops as expected
-Remove the gas, voltage rises again
-If I'm on ships power whether the engine is running (13.7v input) or just jumper power (12v input) behavior is the same
-If I hang the sensor in the exhaust stream from the exhaust tips or from the gas stream from the empty bung hole () same thing, voltage drops, pull it away voltage goes back to 5v
All this is normal behavior.
BUT as soon as I screw the sensor into the bung the voltage remains at 5v and doesn't drop when the engine is running.
The ONLY difference is the sensor is screwed in to the bung. No other differences in power, grounding, where or how I'm measuring voltage......nothing. As I mentioned above, I can even dangle the sensor NEAR the bung and see voltage changes in the exhaust stream.
I've even tried grounding the sensor body while out of the car to see if it was something electrical, nope it works fine.
Why would a wideband O2 not output a correct voltage on the linear output when screwed into the exhaust, but when unscrewed works fine?
Its a RarlyL8 exhaust and a year ago I didn't have this problem. And again, as I mentioned above, there's PLENTY of exhaust coming out of the bung hole () when the sensor is not screwed in.
I can't figure it out!
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 07-13-2019, 05:46 PM
Alan L's Avatar
I had an issue installing mine. NGK, with same Bosch sensor. Contacted the supplier who told me I had not earthed it properly - of course I disagreed. But it turned out he was right.
Regards
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 07-13-2019, 06:33 PM
Regards
Alan
Alan
Can you clarify please? Do you mean there was a potential difference between where you earthed controller and the exhaust?
Was your issue the same behavior as mine?
Old 07-14-2019, 06:24 AM
That sensor behavior is hard to explain. It is almost like there is no exhaust flow going into the sensor when installed. I am using ALM-ADV which works great on my install. I also have an Innovate sensor heat sink installed, which spaces the sensor further away from the exhaust flow (and excessive heat). It has a tube inside that directs a portion of the exhaust flow to the sensor.
Perhaps you could loosely install the sensor to where exhaust would leak past the threads to see if it will output a signal change. As far a grounds go, I have the heater ground separate from the sensor and signal grounds. The sensor and signal grounds (2 blk wires) go the MS sensor ground pin. The heater ground goes to the same engine ground point I have for the coils and injectors. I could not download the ALM-Inline manual due to a glitch, but I would assume it is the same as the other ALM products.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 07-14-2019, 10:21 AM
Alan L's Avatar
Originally Posted by flightlead404 View Post
Alan
It is a while ago now - maybe a decade. I can't remember the details - but it was not working properly - silly numbers, or would not calibrate or similar. I did have it earthed - but there was something inadequate in how I earthed it. They did say the earthing was critical.
Regards
Alan
Old 07-14-2019, 12:15 PM
I have the ALM inline. They specifically told me multiple times, even after I queried them about ground loop issues, to have BOTH heater ground and electronics ground tied to the same place.
It doesn't make any difference. I tried their way, and my way which is elecontrics ground to MS sensor ground and heater ground to engine ground.
I even tried, with the sensor out, to run a ground strap from the sensor to the exhaust, it did not duplication the problem.
There is PLENTY of exhaust passing the sensor. I'm convinced this is an electronics issue but its crazy!
Old 07-14-2019, 02:59 PM
I've heard the 4.9 are very sensitive to rapid temp changes and usually sensors read lean when they're on the way out. I'd have a second to back it against and/or replace this one when it dies (if it isn't already).
"Frankenstein" - 964 C4 chassis/driveline - 993 widebody/Speedster look - VEMS standalone - twin plug high compression 3.6L N/A engine - 945cc cc/min injectors - Bosch 044 pump - GT45 @ 1bar/14psi - non intercooled/wingless - E85 fuel - turbo inlet water meth inj. - 3.5" exhaust - GT3RS clutch + LWFW
Old 07-15-2019, 05:35 AM
Thanks. It's not that it "reads lean" its that it reacts as though its in free air, exactly as as does when I test it on the bench. It's a brand new sensor.
Old 07-15-2019, 10:37 AM
16Volt's Avatar
This might not be relevant but where is it placed in the exhaust?
My 4.2 sensor started reading 14.5 constantly when the exhaust had melted through the wire and was touching the exhaust.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 07-16-2019, 08:00 AM
It's immediately after the turbo, and yes the bung is rotated 45 degrees ish from the vertical. The wires are fine.
Old 07-16-2019, 12:53 PM
full quack's Avatar
Send a message via Yahoo to full quack
Ok, here's a stupid what if......do you possibly have the polarity switched on the O2 sensor? So that when the O2 sensor is hanging in air but connected, it has current flow, but when you screw it into the bung you experience either a double ground or a double feed???
I'm sure I don't have a clue about this....just throwing it out there.
Mark
Old 07-17-2019, 07:08 AM
Mark
Interesting idea. No I've checked the pinouts multiple times. I don't think it would work that way anyway. There's a single +12v input and two grounds, heater and electronics.
Old 07-17-2019, 07:20 AM
Have you tried running the ground for the controller and both grounds from the sensor directly to the engine so there can be no possible potential between the them?
Tony
Old 07-18-2019, 08:09 AM
Tony
Yep. Tied them together at the controller end and ran a wire straight to the case.
Old 07-18-2019, 01:38 PM
The sensor mounted in the bung should have no effect on the operation of the sensor, have you tried installing the kit on another vehicle to see if you get the same behaviour? That would at least rule out something with the vehicle...
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 07-18-2019, 03:41 PM
mark houghton's Avatar
Very strange. Per your comment, and someone else's suggestion that heat may be the issue when screwed in to the bung, try dangling it in the exhaust stream while at the same time heating it up with a heat gun to mimic the heat soak you would get when installed. Even the new sensor may be bad.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 07-19-2019, 05:55 AM
Wow, we're reaching for straws lol
I'll try that.
Another thing I'll try is screwing it into the bung while the engine is running, and see where it starts to read incorrectly.
My gut says its not head related as it seems to happen immediately rather than over time as I think it would do if it were heating up.
More data this weekend hopefully.....
Old 07-19-2019, 10:11 AM
I'll try that.
Yeah, sometimes grasping at straws is all we have. Process of elimination. Weird ass problem you've got there.
Old 07-20-2019, 09:37 AM
I would e-mail Ecotrons technical support to see if they have any insight into what may be going on. When I installed the ALM-ADV for my setup the software was not correct for LSU-ADV sensor. I e-mailed them and they figured out that I had the incorrect software. Not your problem, but they may be able help figure this issue out.
-Dennis
Old 07-20-2019, 10:05 AM
I was convinced it was a bad computer. But then I went back and tested it out of the car just by accident. Now I'm thinking I've had 3 bad new sensors in a row, but this one is not utterly dead just a bit dead. Maybe there's some internal grounding in the sensor that is bad.
In fact, I tested with a Spartan controller I just pulled out of the trash and it exhibits exactly the same behavior, that is the readings work just fine when the sensor is not screwed into the bung, and goes to 5v when screwed in.
I'm about to check all my grounds for the umpteenth time now....Done
Grounds are perfect. Electronics ground is grounded where the MS grounds, with a dedicated 16AWG line to a stud on the crank case where the airpump used to mount. Verified 0 ohms resistance between MS ground mount and several places around the case and the exhaust. Heater ground goes to frame ground in the LHS engine bay where all shields ground (old CDI grounding point).
Edit 2: Returned that sensor and got another one. Both genuine bosch off amazon definitely not the cheapest option. Will test with the new sensor this weekend and report back.
Old 07-20-2019, 01:24 PM
