Initial Start-Won't Run-Ignition?
Alright Brain Trust, maybe you can provide some insight here:
Just finished with the rebuild of my 1976 930. I get it to start, but it won't continue to run. I can get get it to run with someone giving it throttle AND me pushing the CIS plunger down slightly and not letting it completely close. Even then it won't run for very long (<1min). I'm thinking the timing is just way off so I pull up the timing light to check and adjust. My timing light is very sporadic and at times doesn't even work. I then connect it to two other spark plug wires and still no timing light. So now, thinking I have a bad timing light, I take it outside and hook it up to my pick up and it works fine. Does the metal braiding around the plug wires interfere with the operation of the timing light? Can my spark be too weak to run the light and hence causing the engine not to be happy? When it was working the timing appeared to be way off and I was able to get it closer by pulling the distributor and moving the rotor one tooth in the retard direction. Seemed to help some, but still doesn't want to keep running. Here's some background: Engine was in boxes when I purchased. Hadn't run in over 20 yrs. First time Porsche engine build for me, so don't assume anything is 100% correct! I used Wayne's book to do it, and believe I made all of the necessary changes to make the assembly work for the '76 turbo. All fuel lines replaced from front tank to FD. FD was rebuilt by CIS Flowtech. WUR rebuilt by Tony. I checked fuel pressures using the guide here in the forum-all seem good. All fuel injectors are new, but I did NOT flow check them. Felt that I probably didn't need to since WUR and FD were rebuilt and assumed to be tested. Purchased the CDI from a fellow Pelican. He said it worked. I replaced the blue distributor coax wire (it was shorting). I actually spliced it in using a good section of the old one and reversed the leads in one of the connectors so that the polarity remained correct (i.e. ground on outer wire for a CW rotating distributor). I feel decent about this repair, but there is about a 1" section where the splice is that isn't shielded. I would appreciate any insight. If you need more info, I'll get it to you. Here's a short video so you can hear her struggle: https://youtu.be/COdWHByenNs |
Not firing on all cylinders. You’re going to need to get the gauges and go through checking fuel pressures.
But I think getting a good green wire from Timmy2 is the first thing to do. Sent from my iPhone using Tapatalk |
Yes, the braid affects the signal of some timing lights. An old trick is to hook up the inductive lead of the timing light to the coil wire. The light will be brighter and you'll figure out the correct mark.
Spark plug wires are all installed correctly? None are crossed? |
Both fuel pumps running?
Today:
Verified both fuel pumps running. Removed and re-secured plug wires to connectors at distributor cap and really had to bear down on pushing them into the distributor cap. They don't want to go in there! Thinking that I may have had some that were not inserted far enough. Tried to start again. Sill won't run without me pushing down on the plunger. But I did get it to run longer and when it did, it sounded MUCH better (smoother). Also connected timing light to center wire seemed consistent. Also had the timing light inductive pick-up attached to the non-shielded portion of the plug wire adjacent to the distributor cap and it was consistent too.----Conclusion: shielded plug wires DO affect timing lights (at least mine). Tomorrow night I think I'll hook up the fuel gauge again and recheck pressures as well as trying to screw the idle screw down to hold the plunger open a little more. That plunger isn't hard to move, but has anyone heard of them being too "stiff"? |
When you get it briefly running, let it die after 30 secs.
Put your hand on each of the headers - that will tell you if you are missing some cylinders, or have a complete misfire across all 6 - ign/valve timing etc. If you have one or two cold(er) headers - then go looking at those cylinders for fuel/spark. One issue I have found is putting the plug caps on - they can feel right but often are not. They should 'snap' firmly on. Alan |
Could one cam be off? You are 100% sure of your plug wire order?
if the timing is off and it starts it should keep running.
sounds like the fuel mixture is not correct. remove the connector on the rear of the AFM so the pumps run with the key on. adjust the mixture CW until the injectors start to flow then CCW to where they don't flow. adjust the idle up, large screw on TB. that way you don't have someone controlling the air into the engine while you manipulate the sensor plate as you did before. you need steady air in. pushing down means it is too lean, lifting up means too rich. another issue could be power to the CD unit. verify the CD unit is "whining" after shuts off is an easy way to check for power. |
1- I know the wires are in order coming off the distributor.
2- Could one cam be off? I wish I could verify. After completing that part of the build, I felt good that I had it right. I do remember early in the build getting confused with the cylinder numbering (I'm a GM guy). One of the things I have been thinking about, but, again, I believe I got it right. 3-I'll do the fuel mixture/idle screw tonite. 4-I too thought I had a bad CDI because of no noise. Bob Ashlock (the "CDI guy" on the forum) said the 8 pin units on these early turbos don't whine because they aren't on all of the time-only when the signal is received from the distributor. I am prepared to send it to him so he can evaluate on a 'scope. r/ Bob |
then just check for power TO the CD. make sure it is constant with the key on for at least 2 minutes.
I don't think you have the time delay relay on there but I did see capacitor on the power side to the CD unit. don't know if that could cause an issue with power to the CD. cams? seems funny that it would start but not keep running due to cams. if one cam is off, depending on how much, you could bend a valve. if you did the damage is done. cam timing is not hard to check. just pull the upper valve covers and put the dial gauge on. don't want to scare you or start sending you down different roads but since you brought it up, I f you did bend one you can check with a leak down or compression test. you might also consider checking the firing order of the plug wires. I have put them on wrong and it ran, but no power. with that and bad mixture it would not keep running,. with someone else working the gas like you are doing it can be hard to coordinate the how much you need to push on the sensor plate and how much gas the other guy is giving it. the wires coming off the dist CAN cause a BIG change in timing. IE, if you set it up with the engine off so that it is close, it will be way off when you try to start it. this is a problem when guys put on the MSD box and yes I looked to see if you put one on. I did not think about this until now but "IF" they are backwards the timing will retard as you rev the motor. just a thought. don't run down this road unless your other checks don't help you. you can only cross them up if you take the connector apart or splice the wire. |
T77911S,
I don't believe I understand your last 2 paragraphs about the wires and setting up with engine off. Also about the "backwards" do you mean for CCW rotation? Can you explain further so I understand? Thanks |
Here's the results of my fuel pressure tests:
System Press: 7.1 bar (spec=6.0-6.7) Cold Control Press: 2.7 (spec=1.5-1.9 @ 27C) Warm Control Press: 3.3 (spec=2.6-3.0) got there in 1:40m Residual: 5m=1.95; 15m=1.7; 30m=1.5; 60m=1.2 Control Circuit Flow: 285ml @ 1min (spec=160-240ml) Fuel System Flow: 1900 ml @ 30sec (spec=1170) I removed all plug wires and made sure they were all inserted as deep as possible into the rotor cap and double checked firing order vs plug wire orientation. I think I had issues with the insertions of more than one. Got the car to start again. Still won't run without me holding the plunger down, but when it did, it sounded the best so far! Here's a link to the run video so you can hear: https://youtu.be/sGCBM8FIt94 As soon as I let go of the plunger, it dies. So please confirm or not with me that I think it runs without missing, and decent given that the air to fuel is jacked up. If I have to hold the plunger down then that means it is too rich. Can my high pressure readings above be off enough to cause this problem to this degree? My plunger is all of the way up when off. When I unscrewed the access screw, I didn't see anything in there to adjust the plunger downward. Stuck my allen wrench through the hole and can reach the plunger. Haven't figured out how to adjust FD press. Do I buy a shim for a spring somewhere? I think I can figure out how to adjust the WUR, but the FD adjustment may fix this??? I really appreciate your help!! |
oh yeah..... All of the exhaust headers are hot.
Ok, then it is a general condition rather than specific cylinders - based on the headers not showing any difference in heat.
Your system pressure is easy - you are too high, so to get in to spec you remove shims. Take a medium sized one out - if there is a range of them. You undo the nut on top RHS of FD. Carefully remove it - be careful - there can be some pressure behind there and stuff flying out - spring lost etc. Then just take a shim out and re insert. That will drop the system pressure. Your idle setting sound suspicious. There should be a 3mm allen head knob between the FD head and the airplate? It should be sticking up about 1/2". You insert the allen key, and depress until you feel it engage - then rotate slightly, it should lock into a special housing in the airplate arm. Then turn it - anticlockwise - as previously suggested until there is no injector squeal. That is a different noise than the pumps whining. When you depress the airplate you will hear the injectors open/squeal. Let the airplate rest and that should stop and only the pump whine - cycling fuel thru the FD back to tank. This will occur when you disconnect the airplate sensor switch on the back of the airplate - pull the plug (key on). That should get you close to a base idle setting - the injectors should squeal as soon as you crack the airplate open slightly (1-2mm). Then when warm you can tweek the idle mix until the engine runs happy. Anticlockwise is lean. 1/4 turn is a big adjustment - very sensitive. Your Cold WUR pressure is quite high = lean cold start. Alan |
I think you are chasing a leaness problem on a cold engine - which is why you are having to crack the airplate open. The TB butterfly stays shut (no gas pedal action) so no more air going in, but you are opening the metering slits in the FD (almost randomly) to let more fuel in to adjust the mixture.
Alan |
Another possibility is that the o-ring on the FP regulator piston has swollen due to exposure to ethanol in the gas, causing the piston to stick. It happened to me before I converted to EFI. Also, on the early cars, the mixture screw is adjusted using your own allen wrench or a special CIS tee-wrench if you have one.
There is no O ring on the FD metering piston - but good point. It must be able to move freely.
The airplate should be able to move easily thru full travel - best checked when no residual pressure in the system. Alan |
Yeah piston moves freely. Well, I can't actually see the piston, but the plate moves freely and "feels" like the piston is riding on it and following. Also, I'm able to keep the car running by manually pressing the plate down (which in turn moves the piston).
Recall, I had the FD rebuilt by CIS Flowtech. When I got it back, the piston moved freely. I'm concerned that the allen screw that is used to adjust the resting position of the plate at the uppermost point is not correct. There's only a screw and a washer and it doesn't appear to touch the arm of the plate. |
Your early engine may be different to the later ones for the idle adjust screw. But the principle is the same. Maybe post a pic for others. Sounds like the piston is free - you would feel it sticking, and if it follows the plate back to rest it must be free.
You did not state the temp you measured your Cold Pressure at. But if it was close to 27deg C or colder, it is a fair bet you issue lies here (as well as perhaps idle mixture adjust). Regards Alan |
"System Press: 7.1 bar (spec=6.0-6.7)"
Having just adjusted mine, I may have put you wrong which way to shim - mental picture was back to front. You will probably need to add a shim - about 0.5mm thick. Any appropriate size washer will do it if thickness is right. D 5.5mm, OD 9mm. Alan EDIT - sorry to muck you around - you do need to remove shim to reduce. It is a bit confusing looking at the way it shims. You will need to remove 0.5mm of shim - either by dropping an equivalent shim out, or a combo that adds to approx 0.5mm. |
Did you press the CO screw when turning it? The engine sounds healthy/good so thats a big releif for you.
Now you just need to get the afr right. |
So if I'm watching the second video correctly the throttle body is closed and you can get the engine to run by pressing on the air plate.
Pressing the air plate is controlling the fuel flow to an air inlet system that should be providing no air, or very little, with the throttle body closed. So the throttle body has a massive air leak or the intake manifold has a massive air leak and you are just compensating the fuel flow for the engine to run. When the car dies does it backfire or pop in the exhaust or intake? |
UPDATE
I removed a shim from the FD and reduced system pressure to 6.6 bar. It didn't change the Control Pressure. Still wouldn't run on it's own w/o me pushing down on the metering plate. I started pushing the plate fast and slow and the piston is certainly following because I can feel it come back down and "slap" the arm when I quickly close the plate. During this, I noticed that the force I had to use to hold the plate open was quite a bit, and thought that it would be too difficult for intake air to pull the plate down on its own. So I bled off the fuel pressure from on top of the piston by disconnecting the line that comes from the WUR. When I pressed on the metering plate now, it was MUCH easier. So I connected my fuel gauge back up to this line going to the FD but left the other side that would normally attach to the WUR disconnected and feeding into a can. My intentions were to manually control the control pressure with the fuel gauge valve to prevent pressure from building up on top of the piston. After a few attempts, I was able to operate with a lower control pressure and the car ran on its own! It could now pull the metering plate down on its own. So the 3.3 bar of control pressure is way high. I'll have to see it to believe it, but I think the spec of 2.6-3.0 bar is going to be too much, but.... Chime in please with your thoughts, but now I need to figure out how to adjust my WUR to lower the control pressure. |
...I guess I should also verify I have no restriction in the return line. All the lines, filters, etc are new, but maybe a screen or something just inside the fuel tank?
Your cold pressure is too high = lean engine.
You need to fix that first. Then see how it runs. Not exactly a simple fix - pull WUR apart, or knock the pin, or send WUR out - I think Brian (Rarely L8) does them. The system pressure won't fix the CP, but it was out of spec and you have an engine not running right. Get everything in spec first (eliminate the possibilities) then see what issues you have. Alan |
As you Alan and others have pointed out the fuel pressures are out of spec.
What FD do you have, -016? What WUR, -022? I know what Larry does when rebuilding as I use him and his genuine Bosch parts myself. Don't know what parts were replaced in your WUR, where they came from or what spec was set to when completed. Given the CCP the engine will struggle to start and run. Once the engine is warm it should run but may be lean. Having high system pressure can be compensated with high WCP, but not 10% high. The '76 air meter assembly is unique with the adjustment screw being internal. That can be a bit tedious to work with. Is that what you have? I'll see if I can find a picture. |
It is possible he has a big airleak - as previously suggested - pinched IC O ring or similar. But regardless, the thing needs to get back to spec either way - then see what arises. Can't really test for an airleak when engine won't run - other than pressurise the system - I go via the rubber elbow.
Either that or get things back to spec and hopefully better running then chase the other gremlins - idle mix, airleak etc. Alan |
FD is an -016 I believe. Kind of hard to tell since Larry painted it.
lhttp://forums.pelicanparts.com/uploa...1563642271.JPG Tony said my old WUR (-054) was not fixable, so he did one up for me. It looks like it's a -033. Allen screw on the top rear. Is that for adjustment? http://forums.pelicanparts.com/uploa...1563642524.JPG http://forums.pelicanparts.com/uploa...1563642524.JPG Recall when I opened up the fuel return line, I could get the CCP down and the air meter would more easily operate. So I thought that maybe I had a blockage. I disconnected the fuel return line at the FD and could blow through it (bubbles witnessed in the tank), but it wasn't very easy-it took some diaphragm. Should this be very easy to blow through? Could this small about of back pressure cause the CCP to be high? Hoping I may have freed something in the line, I measured CCP again and it's still high. |
That allen screw is a mod - allows you to adjust Cold pressure - as I was referring to earlier -'knock the pin'. That has had an adjuster fitted to the pin. Adjusting the CP just got a whole lot easier - for you. I can't remember which way it goes now. And that mod is a slightly different variation of what I have done - so I am a bit loath to tell you what to do with it. But basically that allen screw is fixed in to the pin and allows you to pull/push the pin very slightly. The pin is fixed in the WUR body - you want to mess with it the absolute minimum. Tweek it once ideally - not up/down/up/down/up/down.
I think you need to knock the pin down to drop CP - but wait til someone who actually knows, chips in. Alan |
-033 WUR is for mid 1970's 3.0L 911 not 930.
If the WUR was rebuilt and adjusted to 930 spec it wouldn't need an adjustable CCP screw. If the adjustable screw works you can loosen the nut and lower the allen head bolt until the desired pressure is reached. That doesn't do anything to help the WCP however. |
Ok. Gonna contact Tony and see about adjusting the WUR.
You'd been better off with the -054 as it is a 930 WUR and will enrich the mixture under boost. The -033 will not, so no extra fuel on boost. There is no such thing as an unfixable WUR, you gut the housing and replace it with all new. Anything less is not a full rebuild.
Wur.........
Bob, I got your email about this thread. I hardly come to this forum (930) and read this thread. First, I would like to call your attention that the WUR you sent me for rebuild was a WUR-022 not a -054 as you stated in post #28. They are completely two (2) different types of WUR. I still have your old WUR on my work bench. The condition of your WUR-022 was so bad due to heavy corrosion. The heater was crumbling and with missing internals. The bottom or lower housing was so pitted that it won’t seal and hold vacuum. I spent many hours trying to make it to work but to no avail. It would take so much effort to make this WUR work as it should. So I decided not to rebuild it just to make money. Then you asked me if I could provide you with a replacement WUR for -022. So I informed you that WUR-033 was the same as your old WUR-022. The only difference between the two (2) WUR’s is the stamped numbers outside the housing. All the internal components are the same. I went to look at my logbook and reviewed the calibration numbers. As a matter of fact, you have a copy of the spec sheet for WUR-033 calibrated using the -016/-022 Control Fuel Chart. Something is not right after reading your posts. I am leaving for Europe in 2 days and have no time to investigate it. I will be back by August 6 and if you send this WUR back to me by August 7 or later would be great. It is almost 4:00 AM now and could not get this thing out of my mind. I will call you later this morning. Thanks. Tony |
Hey Tony, not too worried about the stampings and changing over to a different WUR. You were upfront with me on this and I was OK with a different WUR built to operate the same as the stock one. If my research is correct, I believe the -022 was for the Euro spec 930's and the -054 was for US versions. How much swapping at the factory, who knows.
My question is the conversion for the adjustment that is on the one you made for me. Do I simply screw it in or do I have to loosen it and tap it down to decrease the pressure? Shoot, I'm still not convinced it is the WUR even. There is some back pressure on the line going back to the tank. Is there a spec on that? It takes some effort to blow back through mine. |
if the CCP and WCP are correct it should at least run.
the 033 will enrich the mixture BUT it will just do it much earlier than the correct WUR. the 033 works off of vaccum, not boost. that is once vacuum drops to a certain point it WILL lower the CP. so it may not run right when getting on boost. the other thing is I don't know if the diaphragm would be strong enough to handle the boost. your mixture could be way off. check for air leaks, |
Two different types of WUR.........
Bob, I replaced your WUR-022 with an identical WUR. If I place a tape over the ID number, you can not tell or identify which is which because everything inside and out, including the housings are the same. But the WUR-022 is more expensive than WUR-033 because it was designated for 930 application. Second, WUR-022 operates completely different from WUR-054 (enrichment is done by the boost). We could get to the detail later. I am a little bit distracted at the moment because a family member just passed away this morning about 3 hours ago. And we are leaving for Europe in 2 days so there is a lot of discussion going on now. This is what I like you to do for me: 1). Measure the cold control fuel pressure with the just the 2 fuel pumps running (engine off) and WUR electrical plug disconnected. Test run the FP’s with the pressure gauge attached. This test will only need several seconds to confirm the cold control fuel pressure. 2). Repeat the above test but the return line from the WUR is disconnected and open to atmosphere. Install appropriate fuel lines to collect the fuel (gasoline) during the test. You need just a few seconds and read the gauge and shut it off. 3). If the cold control fuel pressures for the above tests are both high, the WUR is the culprit. The high CCP you are getting could be the result of restricted return line. We don’t know this until you test and confirm it. If the WUR turns out to be the problem, send it back to me so I could investigate it. I will be back by August 6. The family made a decision a moment ago to proceed with the trip. Schedule the package to arrive on or after August 7. Had I known earlier about your problem, we could have tested it accordingly. Thanks. Tony |
I re-tested the WUR this evening with the goal of removing any doubt about back pressure to the tank. The cold control pressure was 3.25 bar. When I disconnected the outlet, it stayed the same. Temperature was 26C.
Based on comments here, I started to get concerned about adding vacuum and boost. When I pulled a vacuum (10”) on the WUR, the pressure increased further to 4.0. I didn’t have anything handy to apply pressure to simulate boost. Now the workshop manual does NOT have a spec for fuel enrichment under boost for the ‘76 and ‘77 models like it does for the ‘78 and later models, so I’m not sure how enrichment is done on boost. |
If your engine is stock and you would like to retain top value and optimum performance you need the -022 WUR. If your engine is modified I would suggest having a Bosch shop rebuild your -022 and putting it in a box for the next guy then install a -054 or similar unit from a 3.3L turbo.
Your cold pressure looks way too high. 90+% chance your issue is the WUR and the settings.
Will leave to Tony to sort - otherwise we will all be jumping over top of him. Alan |
OK. Talked to Tony. He wants me to send him the WUR. I'll report once I get it back, installed and tested. Sounds like it will be around mid August.
I think I will obtain a -022. Let me know if anyone has one. Thanks for everyone's help so far! Bob |
| All times are GMT -8. The time now is 08:57 AM. |
