cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
clutch recommendation
Stock 89, G50, turbo look Carrera. Plan on replacing the clutch with turbo installation. If no surprises, plan on adding a thicker cylinder shim gasket, new ARP Rod bolts, Rings and .5 bar turbo with IC. With this modest increase in power, is the stock clutch replacement adequate?
Thanks,
89 Carrera
Old 08-20-2019, 09:55 AM
If you plan to turbocharge it, definitely upgrade your clutch. My stock 964 clutch only held 3-4psi before slipping so like 0.25 bar
Get a sachs sport clutch with the turbo pressure plate. I went lightweight flywheel with mine and replaced the dual mass but I think yours is already a single mass.
"Frankenstein" - 964 C4 chassis/driveline - 993 widebody/Speedster look - VEMS standalone - twin plug high compression 3.6L N/A engine - 945cc cc/min injectors - Bosch 044 pump - GT45 @ 1bar/14psi - non intercooled/wingless - E85 fuel - turbo inlet water meth inj. - 3.5" exhaust - GT3RS clutch + LWFW
Old 08-20-2019, 10:04 AM
David's Avatar
I’ve been very happy with my Kennedy clutch after over 10 years. I’d avoid Centerforce on a turbo engine.
Old 08-20-2019, 03:52 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Stock clutch will hold .5 just fine if it’s healthy. And THAT is IF you can stay at .5 bar. Once you get a taste of boost..... you want more!!!!
It changes from time to time.....
Old 08-21-2019, 08:39 PM
Scottsdale Arizona USA
KEP G50 Stage I will work like a champ. Save some weight and lag.
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design
+1 (844) URO-PART // modepw@europartswest.com
Old 08-22-2019, 01:44 AM
cmcfaul's Avatar
Sounds like I will need something a bit more than stock as I can see pushing the .5 bar up a bit. as i will have an IC and slightly lowered CR. I just know I will do it.
Chris
89 G50 Carrera
Old 08-23-2019, 12:32 PM
TurboKraft's Avatar
This is applicable to the 1990-98 models, not the 1989 G50.
The stock pressure plate *might* hold if healthy, but the sure bet is a Kennedy Stage-1 with a new 930 spring hub clutch disc.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 08-26-2019, 09:47 AM
cmcfaul's Avatar
Thanks Chris,
Is the setup you describe a thigh master...is it much stiffer than normal? My left knee has some miles on it and not getting any younger.
Thanks,
Chris
89 G50 Carrera
Old 08-26-2019, 10:25 AM
I am happy with my KEP stage 1.
Old 08-26-2019, 12:35 PM
TurboKraft's Avatar
Originally Posted by cmcfaul View Post
Thanks Chris,
Thanks,
Chris
89 G50 Carrera
It's not terrible, but definitely a little more firm than the pedal effort with the factory clutch.
Still very driveable, not an on/off switch, thanks to the spring hub and high friction lining.
Call or email for a quote on all parts.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 08-26-2019, 01:06 PM
David's Avatar
Thanks Chris,
Thanks,
Chris
89 G50 Carrera
I'd say my Kennedy stage 1 clutch is stiffer than my stock Cayman clutch on the same order of magnitude that the Cayman clutch is stiffer than a Honda Civic clutch. Yes it's stiffer but it's not too stiff even for occasional stop and go driving.
Old 08-27-2019, 10:50 AM
