Parting out a hot rod lots of $$$$$$$$$$
Interior: 993 Black Alicante with red stitching for sale,
2 door panels, brake, shift boot and center counsel Looking for offers ![]()
Mike Hakimi Empire Pacific Investigative Services www.epis.us epg@usa.com |
3.5" Exhaust System
For Sale
Make me an offer ![]() ![]()
Parting out this super expensive Hot Rod, due to an accident
I have a 3.8L TT engine for sale, which was fully built (top & Bottom), with all high end parts, No Expense Spared. The engine was built by 911-Design, as we all know Lauren and his reputation worldwide. ENGINE: is a 964 NS case, Potter Rods, big oil cooler, 3.8L Porsche Motorsports piston & Cylinders, GT2 EVO Cams, 993 welded heads, with all the high goodies, High Performance vale springs, High performance Titanium Retainers and spring seats, etc., Billet Aluminum Valve Covers, Huge injectors for E85 fuel setup. All the machine work was done by Aasco Motorsports. (Just the repair receipt from 911-Design was around high $40,000 + $10,000 parts for this engine only and around $12000 for Aasco, machining 3.8L, heads, etc.) Thats $62000 Dollars plus the engine. TURBOS & INTERCOLLER: The two turbos are Custom Garrett GT28 housing with GT3071 Compressors (hand built). Custom Big Full Intercooler with two electronic control fans, Tial Wastegates, Custom headers & Exhaust system, Custom heat shield for the turbos and headers. This costed me over $17,000 ELECTRONICS/COMPUTER SYSTEM: is Haltec with lots of options, including Flex Fuel option. Custom Race Harness, gold pins., Hold down tab for ignition spark plug wire connector. This costed me $8000.00 TRANSMITION: is a G50 with limited slip which is like new with brand new Stage 2 Clutch and light Flywheel. $11000 THIS ENTIRE COMPLETE SETUP IS FOR SALE FOR $50K. This will cost you over 90K to set this up. I have dyno sheet, dyno video, full receipt, pictures, etc. Reason I am selling this, I got into an accident 2 weeks after the car was fully set. My wife will divorce me, if I was going to transfer this into a new car. My loss your gain. Make me an offer, everything on this car is for sale SUSPENSTION: THE COMPLETE SUSPENSION WAS SET BY MIRAGE INTERNATIONAL ERP 935 Front Suspension kit $1850 Offset Camber Plates $630 935 Rear Spring Plate Kit $849 Turbo Tie Rod Kits $235 Bolt on Adjustable Bump Steer Kit $335 Complete RSR Valve Racing Struts $747 Rear Shock Tower Reinforcement $? Coilover Springs $2500 Spherical Control Arm Bearings$? Monoball Bearing Cartridges $260 Trailing Arm Reconditioning Service $400 Adjustable Front & Rear Sway bars$700 Spherical Control Arm Bushing and Bearing $480 A 9K value for only $4300.00 Dollars. OTHER PARTS Battery Relocation Kit $175 Battery Mount Kit Odyssey $145 Battery Disconnect Switch $45 Odyssey Battery $180 Rear Tie down $40 Rennline Aluminum Floorboard $140 Rennline Aluminum Gas Pedal Adjustable kit 4 pieces $350 RSR Style Engine Mount Cross Bar & Solid Aluminum Motor Mount $325 Momo Steering wheel $260 2 GT3 Style Carbon fiber Seats & Seat Brackets $3000 2 set 5-point Harness seatbelts $300 Brakes: These are from a Porsche 996 turbo in excellent shape front and rear Calipers and Rotors $1500.00 Brake Master Cylinder 911/930 turbo kit Sport 23MM & Brake Fluid Reservoir G50 Transmission $250 Tilton Brake Pedal Bias Adjuster Kit $100 Interior: 993 Black Alicante with red stitching Convertible 993 top Exhaust System METHANOL SYSTEM I have an Alky Alcohol Injection System with 5 gallon tank installed in front $700 SEATS: Real Carbon Fiber GT3 Style Seats with black leather and swade and red stiching and Porsche embroidery on the seats, including the mounts. $2400 GAUGES: Porsche 911 Gauges 5 pieces with red LED lights $2700 Porsche 964 Rear Lights: These real lights are in perfect condition. Center, Left & Right $700 DOORS: Porsche 911 SC Driver & Passenger Doors with Sound Proofing $500.00 FUEL TANK OEM Porsche 1978 911SC fuel tank, which was recently professionaly done. $350.00 WHELLS: These are CCW 3 Piece LM5 Wheels, that are 18x12 & 18x10 with Toyo R888 racing tires. Front driver and rear passenger are damaged. Its repairable, since they are 3 piece wheels. Center is mat black and outside is glossy black asking $750.00 Porsche 911 964 993 Sound Pad swade with Porsche RS 3.8 red stiching $100 Other Parts: Master Disconnect Switch Battery $25 Electronic Oil Pump- electrical fluid transfer unit - $150 LED Aircraft intercooler Temp Gauge. Digital inercooler differential indicator gauge. Indicateds inlet, outlet and split temps in Fahrenheit $200
Are the ARP Studs for sale?
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
interested in heads and cams
Hello there, no the ARP are installed in the engine
Hello everyone. All the engine parts are what is inside this motor and I am selling this motor as fully complete with the electronics, plug and race. Or I can take the turbos and intercoller out sale it but not taking the engine apart.
The engine was built by 911-Design and it would be a shame to take it apart. Engine has around 1500 total miles, before I got into an accident.
Why isn’t the car repairable? I saw a GT3 get a whole new front clip from the windshield forward.
![]() Man, sorry to hear about your car. I can't imagine how you must be feeling. Seems you have PMs disabled, so posting on the thread. Quote:
Which depends on what brand/model it is. Any pictures? Quote:
And trying hard to skip quickly over the list of suspension pieces every time i scroll...
'77 S with '78 930 power and a few other things. |
I don't want to spend that kind of money on a salvage title
Just sent you an email re some of the stuff you have listed FS.
Anthony @ Voitureltd Bayside WI. |
Hey Mike,
For my 1996 Porsche 993 TT, Im very interested in buying the Carbon Fiber GT3 Style Seats u listed for Sale? Questions: *Are they still available? *Is $2400 your best offer; or are you willing to go lower? *What condition are they in? *Can you send me images? Please call to discuss. Below is my email address and cell# Thanks ![]() Kevin Kevin.Ford@millercoors.com 414.350.3563 911 SEATS: Real Carbon Fiber GT3 Style Seats with black leather and suede and red stitching and Porsche embroidery on the seats, including the mounts. $2400 |
Mike,
Really sorry to hear about this. :-\ I hope someone steps forward and buys the whole thing, transfers it to another chassis.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Depending on the condition of Seats I will ill offer $1800-2000 or OBO.
Are u still selling the seats? What is your offer.
Not factory seats?
Which manufacture please?
PCA, POC & SCCA long time Member |
call me im interested in engine trans and pedal assy .
