Turbo Conversion - Oil Return/Supply
Hi gents, I was wondering what you all might think are good supply and return locations for turbo oil on an SC conversion. I see no reason to deviate from the 930 design on the supply and gather it from the plate the breather ties into, but I wasn't sure about the return. I do plan to use an electric scavenge pump, so gravity feed isn't really a concern. I considered returning back into the breather plate as well, but would that hot oil be supplied back to the turbo, or am I overthinking things?
Thanks for your thoughts! |
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/964984-oil-drain-plug-return-turbo.html
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/834524-turbo-oil-return-suggestions-please.html I think the drain plug adapters are the best idea. The electric pump is just more work and cost than necessary.
Derrick |
Thanks! I've definitely looked at that solution, but short of the JWE sump plate (which I don't think is available anymore), it seemed like there was a risk of scraping the sump and knocking the drain off. I'm also wondering whether the turbo would sit higher with a stock exhaust system or aftermarket headers. If there's enough gravity, I think I would give it a try, but reviews seemed mixed.
Feed using a tee where the idiot light switch resides, drain back to the breather cover like this (if planning on using an electric scavenge pump):
You can see how I feed mine here:
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Using the existing drain plug is possible as a return location. No need for a pump.
I found someone that made a custom drain cover from the forums here. Another 911sc Turbo Conversion
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) |
Brando
Same here, works great
Turbo powa! 1977 911s. it's cool |
TurboKraft sells the 930 turbo supply hoses so you can set it up like the 930 stock location.
Thanks, guys! What is the factory feed location for the 930? I know it’s on the top of the case, and I always assumed it was the breather cover, but is it tee’d off the oil pressure switch like the BAE kits?
Based on the price of the banjo bolt I can run to my sump plate (I must have an early 83), I think it would make sense to at least try a gravity drain first. Has anyone installed a check valve to prevent oil from backflowing into the turbo if the car sits? It looks like summit/jegs/etc sell plenty of different AN threaded valves. Any reason not to put one in drain line? |
Brando
feed pressure comes from the pressure switch area.
https://parts.turbokraft.com/collections/911/products/turbocharger-oil-feed-line-set-3k-warner You can easily try the drain into...whatever you wanna try but keep your mind open to getting a pump and running back to the tank or better yet the breather cover.
Great, thank you.
I'll definitely keep an open mind. A scavenge pump was a foregone conclusion until I started reading this thread and others. For the cost of a $50 fitting and some AN line, it seems like draining to the sump is worth a try though. I'd ideally not like to sit and wait for the car to cool down after an on boost run though. Is coking still a concern with modern synthetics changed at regular intervals? This is one area that JWE and other race teams may not have been too concerned with considering what I'm assuming is a relatively short life expectancy on a race engine/turbocharger (a complete assumption on my part). Last edited by sigchuck; 08-08-2019 at 09:41 AM.. |
Brando
Synthetic oil has changed a lot of this issue but it'll coke too(needs to be lots hotter though).
Ha ! - the colored balloons are a clever idea. The only drawback for me is, I can imagine my grandkids taking them off and using them for water balloons.
Good idea BTW
Always take the high road, it's far less crowded - Charlie Munger |
It's Perfect |
