NON-930 turbos
What are you running for turbo manifolds?
OBX OEM 930 Rarlyl8 I am still waffling between a NA build and boost, but still leaning toward the stupid side. ![]() |
You'll want Rarlyl8.. trust me :] every now and again you'll catch a set in the classifieds well worth the coin you need to cough up for them!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Stock carrera heat exchangers and 930 j pipe
It's funny because depending on who you ask, the stupid side changes ![]() Back to the stupid side changing, depending on who you ask... What's stupid to ME is spending 10-20k on an engine build to increase power at most, 25-50% above stock (and that 50% number is being damn well generous). The first 4-5psi of boost you apply will skyrocket you past any other than the most balls-to-the-wall N/A build and is barely a tickle on the bottom end assuming everything else is in order.
"Frankenstein" - 964 C4 chassis/driveline - 993 widebody/Speedster look - VEMS standalone - twin plug high compression 3.6L N/A engine - 945cc cc/min injectors - Bosch 044 pump - GT45 @ 1bar/14psi - non intercooled/wingless - E85 fuel - turbo inlet water meth inj. - 3.5" exhaust - GT3RS clutch + LWFW |
912-6 Turbo
I'm running Carrera 3.2 heat exchangers and 930 j pipe on my 3.2L Carrera motor. Easy 300 rwhp 300 rwtq at 0.5 bar with conservative timing.
![]() Sandeep
1966 912 Turbo - Carrera 3.2L - GT3076R - Bosch 044 - Intercooled - 55lb injectors - 0.5 Bar - Tial F46 - Magnesium 915 7:31 - BBS E26 15x9, 15x10 - Link G4X Fury |
Yea, I figure the boost rout will lead to be spending a lot more overall because the power is so easy to get to.
The 915 trans would have to go pretty quick in favor of something stronger. In the end I will have to decide if trying to make a Porsche fast is worth it to me, since they are a fairly high HP pr $ car. |
Brando
carrera intake and obx exhaust.
I may go back to oem with heat as I think I need to turn down the wik a bit. I'm using a gt35r and efi and I'm not rich so the thoughts of killing my engine/car/me is a bit of a deterrent at this point. In october last year I cracked up my front bumper and some bbs knockoffs as well as my rear trailing arm while coming onto boost at about 60mph around a corner. Opened my eyes a bit. My car was running about 20psi or so. It's Powerful....
Turbo powa! 1977 911s. it's cool |
20PSI, dear lord, what kind of compression are you running? What Trans is holding up to that!?!
Brando
8.1/1
930 sb
Modified B&B with a T4 turbine flange:
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
I love my RarlyL8 headers and hooligan pipe. Eliminated the heat boxes that I didn't need for a much cleaner look.
Cheers, Chris 1986 951 SOLD: ![]() |
I run 993 HE with a custom y pipe from Rarlyl8 on one and Mode header w/o heat on another.
I have a set of ghl headers with heat that I am selling cheap. PM me if interested. |
Chain fence eating turbo
Protomotive 1-piece, equal length. No slip joints.
No, they have never cracked surprisingly.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, depending on mood ![]() |
