Are these normal reinforcements?
Are these normal reinforcements? I have looked for these in other pictures posted but have never seen them.
This is a picture of my 1981 SC Turbo which had a lot of work done when the 1976 3.0l Turbo engine and Turbo 4 speed was installed.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
I just see the sway bars in the picture. Can you post a different picture?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Adjust your eyes to the darkness and then look just above the sway bar. Looks like a plate with two holes on each side.
"Frankenstein" - 964 C4 chassis/driveline - 993 widebody/Speedster look - VEMS standalone - twin plug high compression 3.6L N/A engine - 945cc cc/min injectors - Bosch 044 pump - GT45 @ 1bar/14psi - non intercooled/wingless - E85 fuel - turbo inlet water meth inj. - 3.5" exhaust - GT3RS clutch + LWFW |
![]() This looks like the same area on an 81 non turbo. Appears your's is modified but maybe someone with the same year car can chime in to confirm. Mike |
![]() Sorry picture didn't upload https://bringatrailer.com/listing/1981-porsche-911sc-24/ Picture 89 showed the area I believe Last edited by mdj930; 10-02-2019 at 08:40 AM.. |
They certainly look like added pieces used to make the trans mount for the 930 4spd. fit the SC chassis.
The mounting cross member for the 930 4spd. is significantly different from either a 915 or G50 trans., so different cross member attachment points would have had to have been fabricated to mate them all together in an SC chassis. Mark |
gearhead
^this.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
can you post a better pic? will need to do this for my project, 78 930 conversion that will have a short BH 930 gearbox installed.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
I don't get under there much these days but I have an oil change due so once I'm down there it should be easy to get a few more pics.
Without a lift this was not as easy as I thought.
Here are the best I could get. ![]()
Not stock but the welds look good
thanks
I would rather be driving
interesting solution to relocate the trans mounting points and it looks like the rear trailing arm pickups are also moved.
Tidy work. Definitely not stock. Certainly appears to be well thought out.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
