More cars than sense
Correct radio bracket for my '76 Turbo Carrera Blaupunkt Bamberg
So, after months of searching, I finally found a correct U.S. Bamberg for my '76 Turbo (including the microphone).
![]() In the photos I've seen, the preset unit is mounted under the ashtray. But while I have the unit itself, what I don't have is the bracket. Can anyone help? Obviously, I'd love to buy the correct bracket but I'm assuming that's not likely. As an alternative, can anyone help me out with photos/measurements of the correct bracket so I can fab something up? Thanks in advance. Last edited by maninblack; 12-31-2015 at 02:02 PM.. |
like this? I was trying to figure that one out as well
VintageExcellence.com |
For the ashtray mount use this one or simply make a bracket, it will hardly be seen
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Also, how does it mount to the ashtray? |
I got that bracket with a Bamberg I bought a while back. There isn't a part number on it.
The one shown with the tuner on the console is still available from Porsche. 911 552 255 00 It shows its about $ 10 In looking at the parts pfd, i found another support 911 645 137 00 that you might order, but I am not sure its correct. You might want to place a WTB add in the parts forum. To mount the tuner under the ashtray, remove the ashtray from the car. Align the bracket with the tuner in the correct position and mark 2 holes. You must either drill thru the ashtray and use small screws and nuts or use metal screws to attach the bracket to the ashtray. In either case you will have 2 holes in the ashtray As I mentioned, a flat piece of sheet metal would work fine. Use a straight piece of flat sheet metal 6 1/4 inches long and 1-1 1/2 inches wide Use the tuner as your template, 4 1/4 inches in the center with 1 inch tabs on both sides. Drill holes to match and paint with semi-gloss black and mount. Once mounted snugly under the ashtray you cannot tell any different.
Hey Man,
Here is a drawing in jpg format of the bracket you were looking for. Pm me your e-mail and I will try to send you a better copy if this doesn't work. Best, Rahl ![]() Last edited by 356911930; 01-06-2016 at 06:49 PM.. Reason: additional info |
3 restos WIP = psycho
Any sheet metal shop can fab the bracket from those plans. Excellent resource.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Thanks, guys. Much appreciate each of you taking the time.
Rahl, you have a PM. |
Bland
Mine does not have the microphone bracket. The mic is in the footwell pocket.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Banned
pm sent
I believe this image is from a '77 onward, not the '76. The '77 had the retractable cord mic with the Bamberg which was fitted in the center console with above the A/C controls as shown in this pic. The '76 had the mic attached to the station preselector as the OP showed, I believe that '76 mic has the coiled cord (non-retractable).
'72 911 ST Tribute (built by Scott Longballa) - Signal Yellow '74 911 Carrera Targa (2.7 MFI - RoW) - Silver / Polaroid Stripes '77 930 - Minerva Blue '97 993 Turbo S - Ocean Blue Metallic '13 981 Boxster (BGB 3.8L 991S conversion) - Racing Yellow |
Non User
I know this is a revival, of a 3 Y.O. thread, but the ashtray bracket is what’s in my ‘76, radio long gone.... it’s the same as the eBay piece...
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
