Drive it like u stole it.
Project Resurrection (after 8 years)
So I am finally finding some time to get back on this old project of mine. Its been so long I almost don't remember what parts I have stashed away so every box has a little surprise in in. I figure I should try to put as many parts on the car at this point to figure out what I still need and get rid of some boxes while I'm at it. I have lots to do to be honest.
First project: Rear Brembo Brakes (I did the fronts a few years ago) ![]() ![]() ![]() ![]() ![]()
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
Good for you Bill.
I know how this is to have to walk away from your project to take care of and deal with other things. I too have that situation. However, its fun when you get started again.. as you said, making discoveries box after box! Good luck!
RGruppe #180 So many cars.. so little time!! |
Looks like fun. Keep it going. How long has it been sitting on the Quickjacks?
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
Sweet ride. If that was in my garage i'd have a hard time NOT working on it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
and I thought being at 6 yrs on this project was a LONG time.....
curious about the rear calipers. look like SC not 930. my project was an SC converted to a 930 in 1989. guy left the SC suspension and brakes. just finished blasting to metal. now to do some final grinding, sanding, and cleaning for primer and paint. in the process of dismantling I got a proper set of 930 calipers along with revalved bilstein F/R shocks and raised spindle RS reinforced front struts. good luck.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold ![]() |
These are SC backs but the car is full of 930 parts from a donor car. Sometime in its early life (before 1984) the car was converted using 1976 930 parts including the suspension, engine/trans. and body parts. The rear banana arms are from a 76 930 as are the brakes. The early 930's (3.0L non IC) cars did not have the big desirable Turbo brakes the 78-on had.
Tags |
brakes , brembo , rear |
