930 CV boot flanges anyone have some spares?
I have this set of axles I have to deal with, the car was pushed back and forth too many times in an overcrowded shop so the axles rubbed these flanged over and over. I see porsche sells them new but at $175 each but that’s fairly expensive.
Anyone have some old used but straight 930 cv flanges around? I need 3 of them. or I’ll buy the whole axle if they are cheap. http://forums.pelicanparts.com/uploa...1572450449.jpg |
I have a couple of original axles off an 86 930. Will they work? let me check in the shop this weekend.
the 86 flanges are different. doesnt use the thick ones. 86's use thin stampings with a cap on the mounting ends
Let me know if you plan on tossing those - I'll take them.
Thanks |
I think I found a set of 3, doesn’t surprise me the later ones are diff. Pain in the butt, lesson is tie your axles up so they don’t dangle or remove them while the motor out.
Rawknees always says shaft dangle=butt pain
| All times are GMT -8. The time now is 04:21 PM. |
