-   -   bench testing an engine .. Help needed (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1053243-bench-testing-engine-help-needed.html)
gorskined 02-21-2020 06:30 AM
My build is currently stalled due to waiting for some machine shop work and a few custom parts ... so i would like to spend the next week building a test stand to run the motor out of the car .. I'm sure this is not the first time this has been asked but i cant find any references under searches.
Can anyone point me in the right direction with the electrical end of the equation?
a little background full rebuild on a 76 row turbo pretty much stock build sc cams and with a andile intercooler the bench will consist of a battery a tac a oil pressure gauge oil lines in and out through a small oil cooler a dry sump tank small fuel tank and a fuel pump oil filter what i am missing is a wiring diagram on where i need to connect power to the existing engine harness .
any guidance would be greatly appreciated
Regards Ned
80 sc steel wide body 911 with a 3.0l 76 row turbo ( fair weather driver )
55 356 continental cab ( concours car )
Alan L 02-21-2020 03:03 PM
Tony - in the 911 Tech forum (can't remember his handle - BoySC??) has such a thing - have seen a pic in one of his threads. Maybe search thru there.
Alan
