930 hesitating on low RPM
HI
We have a 930 turbo with the following problem
- On low RPM 1000 to 2500 hesitating on little throttle. (like misfire the engine)
After 2500 RPM the car pulls really nice
I have checked the follows
- Ignition system Ok (cap, rotor, cabels , plugs new)
- Fuel system WCP 3.6bar system Pressure 5.2bar(this a bit low???)
Any idea?
Zoltan
Old 03-26-2020, 05:50 AM
Originally Posted by himizoli View Post
HI
Any idea?
Zoltan
You don't mention the coil? Also, when you say cables does that include the green wire and also the two leads to the coil (mine were separating at the crimp)?
What about individual injector flow rates and spray patterns?
Idle mixture?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 03-26-2020, 08:09 AM
Yes, the green cable is also new.
The Fuel distributor is recently rebuilt, spray pattern are ok.
The Idle mix is AFR 12,6
If I rev to 1500RPM the car the AFR goes 15 around and making the misfire.
Old 03-26-2020, 09:30 PM
Crotchety Old Bastard
RarlyL8's Avatar
Is this a Euro or USA (Lambda) engine?
Have you checked the air meter plate is free and correct height?
Old 03-27-2020, 04:51 AM
This is a EURO 3.0 year 1975.
The WUR is 054.
The air meter place is moving freely. ( I pushed down and comes back easily)
What you mean about the correct height?
Old 03-27-2020, 06:01 AM
The WUR is 054.
Euro 75 so no Lambda sensor or valve, correct?
Old 03-27-2020, 06:36 AM
No lambda sensor, no extra injector on Fuel distributor
Old 03-27-2020, 06:50 AM
So you're getting a lean stumble when you come off idle.
There are (if the '75 is the same) some different ports in the throttle body that provide vacuum sensing for various things such as advance/retard in the distrubutor.
Perhaps you have one of those ports not connected, or a leak somewhere in a line such that when the port is covered/uncovered you're getting an unmetered air leak and going lean?
Or some other air leak and the idle mixture has been turned up rich to compensate, and you're loosing that band aid coming off idle?
Old 03-27-2020, 02:02 PM
RarlyL8's Avatar
That's the wrong WUR for a '75 but shouldn't have anything to do with the stumble.
Does this stumble happen when the engine is cold or warm or all the time?
Can you get AFR and fuel pressure readings during the stumble?
Checked for air leaks?
Old 03-28-2020, 05:13 AM
Checked for air leakage, find one but the stumble still comes.
Installed a AFR gauge and on idle everything fine AFR 12,6
Start to drive and stumble comes 1500 to 2500 Rpm , the AFR goes up to 15,5...
After 3000rpm the carb pulles very hard and AFR is 12-13
I think still I have air leaks....
Old 03-28-2020, 09:55 PM
I think a warm idle mixture of 12.6 is a bit rich. I found mine to idle best around 13.8.
Others may have different experience and ofc I'm running a 3.3 1986 car
Old 03-29-2020, 09:40 AM
I was set the WCP to 3.0Bar and it makes better, but still comes the stumble 1500 to 2500Rpm. The AFR abound 14 in this RPM range....
Old 04-03-2020, 02:59 AM
You mentioned there's a cdi box under the seat, is there a narrowband sensor in the exhaust? Is there a lambda valve on the fuel head? If so, is it buzzing?
I don't remember the details off the top of my head but I think if there's a lambda valve but its not connected at all it is open, and if its powered but not controlled its around 50% duty cycle. I could be way off here perhaps someone can correct me if so.
So, normally it would be running around 50% duty cycle then controlled by the cdi box below (I think 3,000 rpm) to get an idle mix meeting the emissions requirements (call it close to stoich).
If the lambda valve is then disconnected and fails open we then reduce the control pressure, thereby richening mixture. If the idle mix is then adjusted lean to get it back to a reasonable idle maybe that would cause a lean stumble coming off idle?
Just spitballing here....
Old 04-03-2020, 06:53 AM
