would like some one to read my spark plugs after adding the turbo
Its been a few months and about 500 miles since I start driving my turbo'ed Euro 3.2, today I decided to check the spark plugs just to see how they read, I would like to hear your opinions :
![]() ![]() Thanks...
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
Those look good to me.
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) Last edited by flat6pilot; 01-09-2022 at 10:10 PM.. |
They look pretty good to me. If anything, I’d say they’re on the rich side which isn’t bad on a turbo as long you’re not washing the oil off the cylinder walls. I was told to look deep down the insulator to get the best reading but I’ve never seen anything down there that I didn’t see farther out. How was the car driven before they were pulled?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
hard to tell, but they look OK to me. 4 looks wet - maybe oil?
Did you chop throttle and ignition prior to pulling to avoid having the idle mixture affect the plug color? If you hit a dyno to tune to your new turbo, study the AFR readings to ensure your mix is in the range you want it to be.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Agree on the dyno, that’s a small price to pay on a new turbo or efi system.
I agree. They look good with the exception of #4. It looks wet. Maybe a tad on the rich side but from the looks of them not much. Do you have a air/fuel gauge?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
I agree that 4 looks a tad wet, but not too alarmingly so. What's the plug gap you're using?
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) |
Yep, those are spark plugs alright!!!
Ok enough of the smarty pants. It means absolutely nothing if you didn't do a proper plug check. The only way to check the plugs is to do a hard full throttle pull and cut the power. Then look at them. If you drove around the block and idled back into your garage, the plugs will reflect that driving. Typically the way to do this is to put in a brand new plug into the cylinder that is the easiest to remove. Then go for a drive and take your plug socket and another plug with you. Pick a quiet piece of road and do a hard pull and a full ignition cut. Coast to a stop and remove the plugs and refit the other one you bought. Then drive home and then look at it. Read the write up on our web site on how to read a plug. Are you looking for correct fueling or ignition timing. The plug will tell you both but in different places. Good luck. |
BTW, the easiest plug to change may not be the one showing the most incorrect fueling etc.
Thanks to all of you for your thoughts, you are all been a big help in my P projects. The car ran fine and I just wanted to make sure that my fuel/timing is at least not causing any damage to the engine. reminding you that its a Euro 3.2 with a GT35 turbo, so I maybe tickling a sleepping dragon's tail here!
In the Ford Eco Boost turbo engine requires spark plugs be changed at 96,000km vs 120,000 in none turbo engines. The reason for having to change the spark plugs sooner in a turbo charged engine is due to how much more heat they have to endure. This will cause them to ultimately wear out sooner.
MyMileStone Card Last edited by Richardss; 01-18-2022 at 08:20 PM.. |
