turbo engine install height with IC
Hello all
i was hoping to take a little guesswork out of installing my 76 3.0 with a long neck i/c motor and would like to install the motor as a complete unit with the i/c attached . i've installed many non turbo motors years past but never really paid attention to the height .so i have a few question 1 will the ic clear with the rear bumper attached ? 2 how high do i i need the car? ( distance from torsion tubes or rear bumper to the ground. Thanks in advance Ned |
Ned I can’t help you with the measurements even though I did this two weeks ago, sorry. My front spoiler rubber lip was touching the garage floor to remove my engine with the bumper on but intercooler and air box off.
What I will tell you is removing the intercooler is highly advised and probably mandatory. My turbo up-pipe exits from the turbo and then kicks back towards the rear of the car, meaning the rear of the intercooler is rearward beyond the car’s sheet metal where the engine seal goes. In other words, you couldn’t go straight up with it installed. Perhaps if you slid the trans shaft waaay in the tunnel to go forward, and then come back with the whole thing after the intercooler is above the rear shelf maybe it would work. For the xx minutes it takes to r&r the intercooler and air cleaner, you couldn’t pay me to try to do it with them on. And of course the car has to be even higher than usual to try. Also, access to the rear harness connector, fuel lines, WUR for pre-start fuel pressure checks, and mailbox breather hoses is vastly made easier with them off. |
Having done this a few :( times I've always done it with the air filter/air box and the IC removed. Remember to use a job shop rag, rubber glove, or some plastic and blue tape or something to seal off the turbo outlet and fuel distributor inlet.
Remember to remove the shop rags before reassembly and starting the car http://forums.pelicanparts.com/support/smileys/chix.gif What I've found with the non-stock IC is that there's a little jiggering and "negotiation" to get the thing positioned correctly so the up pipe doesn't interfere with the inside of the engine bay lip and the IC doesn't interfere with the AC hoses if any. That can only be done once its in the car. |
| All times are GMT -8. The time now is 05:24 AM. |
