Anyone using a CAN Buss Gauge with ECU?
I'm thinking of swapping out my AFR gauge and using CAN buss with this instead.
Is anyone using something like this or this? If so, feedback?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! Last edited by flightlead404; 08-14-2020 at 08:45 AM.. |
I have an AEM infinity and built my own canbus multigage. I owe you guys a thread on it in the future. I replaced the clock and can output anything I want. Moreover, I can inject accelerometer/gyro/gps data.
Ironically, the only gage I am missing to add is the clock gage that the multigage is replacing. I have a screen where I show the most important parameters for me for tuning with boost. It shows AFRs, Boost, IAT and Injector feedback all in one screen. No need to lug a computer around anymore. I really, really like having the data so readily available.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
That was my plan until I saw these.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Teensy should work. I used an Arduino mega with a canbus adapter and a 3 in display. The display is mounted on the clock hole but from behind. I wish I could get it closer but that means a smaller display. No one makes a decent round screen.
I also built kind of an armrest between the seats to hold the hardware inside. I will be mounting switches there.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! Last edited by Dr J; 08-14-2020 at 08:14 PM.. |
I like my clock, but I've designed/printed a really nice 52mm gauge holder to replace the radio.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! Last edited by flightlead404; 08-15-2020 at 06:06 AM.. |
Have you looked at Perfect Tuning: https://perfecttuning.net/en/gauge/54-universal-gauge.html. It will work with Microsquirt.
I have installed this with my MS3/MS3X install. Get all info to the gage over the CAN Bus. I have a thread here where I install it in place of the clock, had to make an adapter to fit the gage into an empty gage/clock housing. Perfect Tuning Universal Gauge for MS2, MS3, AEM
-Dennis 1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R |
I'll look at your thread. If its not in the thread, are you able to get AFR, Boost, ign adv, and iat on the gauge?
You can select one, two, three or four functions to view on the gage at the same time. I am not familiar with Microsquirt, but any basic functions that you can log in TS should be able to be displayed on the gage.
Megasquirt forum member Suprazz developed and produces this CAN Bus gage. You could email him: support@perfecttuning.net with any questions.
You can monitor just about any parameter from Megasquirt. It even has a shift light setting.
I would rather be driving
I also have a Perfect Tuning gauge connected to Microsquirt. Works great. It has multiple screens and each screen is configurable for what parameters you want to show.
I 3D printed an adapter ring for my clock hole that uses the stock clock trim ring. You could use the glass cover plate as well but that covers the config buttons.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
The gage mounts in a 52mm opening, but the display steps up to 69mm.
