installing cam sync
about to install the cam sync on the smog/scavenge pump housing.
do I need to set the engine to TDC or a few degrees BTDC I need to use a bolt and nut on the pulley gear correct. what is the gap also, I have 2 knock sensors installed on #2 and 5 heads under the fan shroud. any ideas for perhaps mounting a connector on top of the fan shroud or how to get the wiring in there |
This is my head temp sensor and wire exiting on the right
Knock sensor is on 2 and 5 http://forums.pelicanparts.com/uploa...1600353140.jpg |
ms3 evo.
I think I found it. at least 3 teeth BTDC. |
Knock sensor install question? Did you just drill the heads and use a stud and nut to fasten the knock sensor? I need to do this to my heads before installing them.
David |
Ups, my cache showed this one as new post, but anyway:
For Cam sync I used this advice: Quote:
for the temp sensor and Knock sensor I had the heads drilled and threaded.
one knock on each side. |
| All times are GMT -8. The time now is 05:54 AM. |
