-   -   Revert to OEM muffler but keep dump pipe (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1073644-revert-oem-muffler-but-keep-dump-pipe.html)
Topocalm 09-20-2020 11:29 PM
Hi,
I want to revert back to the original muffler but keep the waste gate dump pipe. For this I would need to close the pipe / connection for the OEM setup where the wast gate gets connected to the main muffler.
Is this sensible? How do I best close the pipe?
reclino 09-21-2020 06:53 AM
To do it cheap I would carry it to a muffler shop and have them weld up a cap that will slip into the stub then clamp it to the muffler. I have a few extra 924 turbo pipes from the wastegate to the muffler I believe these are the same size. Let me dig around and find one, you could cut it down weld it into a "plug" then slip in and install with the factory clamp and gasket... Not sure what the pipe is worth. Shipping to Germany might take forever and cost too much.
icemann427 09-21-2020 08:56 AM
I, personally, hate the sound of the unmuffled waste gate pipe. Even with my aftermarket performance header/muffler system that sounds really great, I can still hear the waste gate. I've thought about putting a muffler back onto it (waste gate), to quiet it down. I can only imagine what it will sound like with a stock muffler reaffixed...
flightlead404 09-21-2020 12:34 PM
I've got a wastegate muffler for sale if you're interested. pm me.
timc 09-25-2020 03:51 PM
Originally Posted by Topocalm (Post 11033715)
Hi,
I did that years ago, picked up a muffler for a 79 that re-circulated the WG back into the muffler, cut off the recirc pipe, welded a round piece of metal to cover the hole, and picked up a un muffled WG dump pipe.
I may still have the WG muffler, if I can find it you can have it, as I'll never use it again.
