Topocalma
Revert to OEM muffler but keep dump pipe
Hi,
I want to revert back to the original muffler but keep the waste gate dump pipe. For this I would need to close the pipe / connection for the OEM setup where the wast gate gets connected to the main muffler.
Is this sensible? How do I best close the pipe?
1973 2.4T gemini blue
1977 3.0 Turbo slate grey
1973 2.4s motor rebuilding project
Old 09-20-2020, 11:29 PM
To do it cheap I would carry it to a muffler shop and have them weld up a cap that will slip into the stub then clamp it to the muffler. I have a few extra 924 turbo pipes from the wastegate to the muffler I believe these are the same size. Let me dig around and find one, you could cut it down weld it into a "plug" then slip in and install with the factory clamp and gasket... Not sure what the pipe is worth. Shipping to Germany might take forever and cost too much.
Old 09-21-2020, 06:53 AM
I, personally, hate the sound of the unmuffled waste gate pipe. Even with my aftermarket performance header/muffler system that sounds really great, I can still hear the waste gate. I've thought about putting a muffler back onto it (waste gate), to quiet it down. I can only imagine what it will sound like with a stock muffler reaffixed...
Old 09-21-2020, 08:56 AM
I've got a wastegate muffler for sale if you're interested. pm me.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 09-21-2020, 12:34 PM
Originally Posted by Topocalm View Post
Hi,
I did that years ago, picked up a muffler for a 79 that re-circulated the WG back into the muffler, cut off the recirc pipe, welded a round piece of metal to cover the hole, and picked up a un muffled WG dump pipe.
I may still have the WG muffler, if I can find it you can have it, as I'll never use it again.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 09-25-2020, 03:51 PM
