brake light problem
hello, I have a brake light problem on my 1984 targa. The light only comes on when I press very hard on the pedal.
I looked behind the brake pedal and near the master cylinder to find an adjustment, but found nothing.
Sorry for my English because I am from Quebec
Guym
911 targa rouge
1984
Old 09-15-2020, 12:27 PM
This may help:
Help, No brake lights
switches seem to be located on the brake master cylinder.
Is brake fluid level adequate?
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 09-15-2020, 02:57 PM
The oil level was low, I added more and pumped the brakes a few times and it didn't change anything.
I may not be enough to press the pedal?
Guym
911 targa rouge
1984
Old 09-15-2020, 03:10 PM
Bucketlist's Avatar
There are lots of brake light threads on here mainly because these cars weren't very sensitive to brake pressure. Some of us mounted electrical brake light switches which work very well.
Manual Brake Light Switch
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 09-16-2020, 03:07 AM
Thanks, I'll install an adjustable one too.
Guym
911 targa rouge
1984
Old 09-16-2020, 03:28 AM
Jeff NJ's Avatar
Since that thread that hot euro posted also has my fix in there along with my flashing led 3rd brake light, I thought I'd give an update since it's been 3.5 years.
The brake light still comes on with a very light tap of the brake pedal, so you can tap the brakes without actually braking to let those behind you that you are going to slow down. The flashing brake light really works well too. It's a great upgrade that requires zero permanent modifications and certainly reduces the risk of being rear ended.
1988 930 Venetian Blue
Old 09-16-2020, 04:43 PM
problem solved.
after filling my reservoir with brake oil and Going a ride, it will be back to normal.
Thanks for your help.
Guym
911 targa rouge
1984
Old 09-20-2020, 04:19 PM
