Routing AFR cable
So how are you guys routing your AFR cable from the passenger compartment to the engine bay without drilling a hole?
SR 86 930 x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette. |
You need to remove your rear deck panel and access a hole on the left side where other wires at. Then you can route it under the left side rear panel and down by the lower left sill carpet. I’m sure guys have probably done it using the transmission tunnel too.
Rey....77 930 "the Mistress" |
Mighty Meatlocker Turbo
On the far, back left (on the vertical panel between the left rear seat bottom and the floor) of Turbos from the mid 1980s there is a large hole that is simply plugged from the factory with a glob/smear of sealer (it is for tubs that used Motronic FI and is the hole for its wiring harness) - you can poke a hole in the sealer, or remove that spot all together, and route the wiring through there. I removed it on mine, and then glued in a large, perfect sized washer, ran the wiring through the washer's hole (
) and then sealed the hole with a rubber grommet.
Brando
Trans tunnel but you’d probably want to wait till you drop the engine for that access.
Turbo powa! 1977 911s. it's cool |
When I bought my Innovate lm2 several years ago it came with a cable (maybe 8') too short to reach the rear comfortably. I bought a longer cable (maybe 12') ran it under the dash, under the carpet past the driver's seat and through the hole described above. I had plenty of length to reach the O2 sensor plug keeping out of harms way.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
Thanks, found it. Makes this job easy.
As I mentioned the runs are in a chafe/oil/fire/heat resistant fiberglass snake skin sleeve in the eng compartment until inside the cabin. Ends of the sleeve sealed with adhesive lined double walled heat shrink.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
As stated above, 84 and later have a hole in the vertical panel below the drivers side rear seat in the corner for Motronic harness. Mine just had a rubber plug.
