Fuel Pump(s) Switch
Ignition barrel is worn and priming fuel pumps for a cold start can be a touchy subject. Has anyone wired a dash-mounted fuel pump switch on a street car? Pros/cons? Easy job? The car is a mostly stock '78 3.3L. I don't really care about originality.
Old 10-30-2020, 05:58 AM
Crotchety Old Bastard
RarlyL8's Avatar
Replace the ignition switch before it strands you.
Old 10-30-2020, 06:54 AM
Yes. Top switch is pumps, bottom button is for CSV.
And before I get a bunch of "you're going to get burnt alive because the pumps won't shut off when you roll it", the original air meter contact sw is disconnected and replaced with an inertia sw in the engine compartment. This eliminates the air meter contacts and the stupid red relay. I also replaced the original round pump relays in the fuse box with modern Hella's.
Old 11-08-2020, 05:04 AM
Not to be picky, but yellow relay, right? At least the standard one is a yellow relay. I've long had a standard square relay there, couple of bucks vs the ~$300 yellow one.
It doesn't even need to be a red relay or a relay with a quenching diode as its not an inductive load.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 11-08-2020, 09:24 AM
No, it's red. It's J16 on the circuit diagram for a '79. Located on the back electrical panel. The coil terminals 85 and 86 are in the same line as the air meter contacts. It has the diode to protect the air meter contacts. I jumpered 86 to 85 in the relay block and I use the juice from 85 to supply my Pierburg valve and then to the MSD RPM sw. My inertia sw is across terminals 30 and 87a of the same block which then goes to the boost limit sw. My dash sw for the pumps is in the line supplying power to the pump relay coils (86 and 85) but it is switched 12v so downstream from the ign sw.
Momentary on button for the CSV eliminates the stupid thermo-time sw.
Blew the doors off a '70 SS 396 Chevelle today, caught 2nd and went by him like he was standing still.
Old 11-08-2020, 07:38 PM
Bucketlist's Avatar
Where did you mount your inertia switch?
I've had one on the shelf for a while and need to install it.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 11-09-2020, 03:48 AM
It's off a '90 F150.
Old 11-09-2020, 10:05 AM
Location: Địa chỉ: 58-60 Quốc Lộ 1K, Phường Linh Xuân, Quận Thủ Đức, TP.HCM
It will be difficult if you have no experience. Take it to the repair shop and it won't cost much
Old 11-26-2020, 04:53 AM
