Adding a turbo to a 2.7 to compensate for altitude loss?
Hi everyone, I have a properly rebuilt 2.7 with case inserts head studs etc that has been nothing but reliable but the thing is I live at 9500ft altitude and doing a quick calculation If you lose about 3% hp per 1000ft I'm loosing ~27% hp. So I've been thinking about installing a low psi turbo just to bring it back to stock hp levels, is this just plain stupid or does it make sense to anyone to try this? Any input is greatly appreciated
Best regards Jake
"It's only temporary unless it works" 1974 911s turbo-look stock 2.7 engine "Dirty Martini" 1953 replica 550 spyder built from the ground up, EJ25 engine Speeduino ECU |
Makes perfect sense.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
Brando
It has been done. Good results with even more boost as well.
Turbo powa! 1977 911s. it's cool |
