-   -   Cyl 2 and 5 lean, This is how I fixed (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1087830-cyl-2-5-lean-how-i-fixed.html)
heliolps2 03-07-2021 05:58 AM
UPDATED! Cyl 2 and 5 lean, This is how I fixed
Hello Turbo friends, When I removed one of my heat exchangers and noticed cyl 2 was very white , see pics posted above, then I removed the other heat exchanger cyl 5 the same . This isn't the first time I've experienced this and fixed this problem with success.
I tested the fuel system, removed the fuel line from the injectors at WOT, and got perfect results. OK, I thought, Maybe bad injectors, so I tested the injectors at idle and at 10% and 25 % throttle then WOT and again got perfect results. as they should, they are new.
I talked to Chris at TurboKraft he suggested that I adjust the fuel head-on cly 2 and 5 !. I removed the little caps next to the fuel line and turned it clockwise 22 deg and started the motor, It started fine and idled perfectly. I will drive the car for the next few days ( 70 deg day coming up in the DC YES !) area. I will check my EGT's the best I can using my inferred temp gun, and check my AFR's with my Innovate handheld unit.
In a couple of weeks, I will remove the heat exchangers and check the color of cly 2 and 5 again, From my test drive. it seems to be spot on.
Even a freshly balanced CIS system is not going to ensure even fuel ratio tuning per cylinder as there other factors inherent in the 3.3 / 3.6 CIS design.
Different primary tube lengths make for variations in reversion per cylinder and thus cylinder filling, the pancake intake manifold seems to flow better to the two center cylinders, and the flat 6 design makes for two center cylinders that are just going to run hotter. On top of that air/oil/, fuel cooled motors have less effective cooling systems and naturally run hotter combustion tempshttp://forums.pelicanparts.com/uploa...1615125458.jpg
Dominik 930 03-07-2021 09:28 AM
Thank you for this contribution. I am excited to see what will come out
RarlyL8 03-07-2021 11:59 AM
I did a write up on this a few years ago. The pancake manifold has shorter center runners which is cyl 2&5. Result is more air to those cylinders causing them to run a touch lean when compared to the others. Pull the exchangers on any 930 any you will typically see this. Enriching the fuel flow to 2&5 will balance the AFRs.
heliolps2 03-07-2021 01:31 PM
Hi Brian,
Yes sir I did, At the time it was my yellow car with a highly modded 3.3. I wasn't expecting to see the same thing on this mostly stock except for the cat bypass and RUF 0.9 bar spring on this 3.3 965.
What I read from someone was if adding fuel to some ports, it will lean out a little on the other ports. and I'm okay with that. Have you heard of that? Thoughts?
Helio
RarlyL8 03-07-2021 05:39 PM
If assuming that the fuel distributor delivers 100% then taking away from that total to add to cyl 2&5 will decrease the amount left for 1,3,4 & 6. This amount is so small that you can easily compensate for it. Off the top of my head I believe the change to fuel amount was around 5%, but this varies engine to engine. If I recall you did this with the yellow 993tt/Gt2 clone, this should be similar even with Lambda. Once the adjustment is done the Lambda system will lean out all 6 cylinders similarly. Really nice detail, props on doing that!
1979-930 03-07-2021 06:51 PM
I hate threads like this.
Now I want to drop my exhaust and check for a lean condition.
How much should you turn the screw clockwise on a 79 fuel head for a 5 % increase if I find an issue?
RarlyL8 03-08-2021 06:21 AM
It's not really an issue, more an exercise in optimization. The 930 fuel system is well known for being overly rich, this is likely one of the reasons why.
heliolps2 03-08-2021 09:19 AM
Thank you, That's what I thought, Well said, I'm going to share your words on Rennlist, It will be helpful for the 964 Turbo guys, Some of them will appreciate the knowledge
heliolps2 03-11-2021 08:26 PM
Lets us know what you find and we will help you on how much fuel you need to add.
Alan L 03-13-2021 10:11 PM
I try and tune my cylinders to 2% (matching) or better if I can get there. While the 2/5 thing makes sense I have never seen the signs of them running leaner - and they get a hard time - mostly WOT.
But as Brian says - usually on WUR dump - which is generally on the rich side for most but the upper rev range. And on upper revs only briefly - have to change gear some time.
I am about to retune after a total fuel system rebuild. I try and match 2/5 to the rest.
I guess it will show up more on low/cruise revs.
Alan
RarlyL8 03-14-2021 07:10 AM
Every set of OE exchangers that I have ever removed had this same 2/5 light gray color pattern. Those cylinders were likely not lean but rather the 1/3/4/6 cylinders are rich. I'd say that tuning for an equal AFR on all 6 cylinders would produce more power and allow some tweaking of the timing and boost level as well.
Pat RUFBTR 03-14-2021 11:34 AM
Hello,
It would be nice to have this tuning technique here with pictures.
Alan L 03-14-2021 11:56 AM
I will be doing mine this week - just waiting for some parts - fuel pump and filter.
Can take some pics.
But there are some threads on this also. Will be same in 911 forum if not on 930. Tuning the FD is the same for my SC as for 930.
Alan
RarlyL8 03-14-2021 05:32 PM
Disclaimer - we are only random guys on the internet, fuel system tuning should be done by a professional.
There you go, don't want someone getting butt hurt 'cause they screwed this up and burned a piston.
Alan L 03-14-2021 05:45 PM
What I am doing - in a day or so, is just balancing the injectors out. This is the process you would go thru if you want to put more fuel in 2&5. Balance them out - then add a bit more flow to 2&5. I run mine all the same - but can post the process if that is what is being asked.
Just installed new filter, now waiting on a pump. My rear pump is lazy - too much pressure differential between the two (5 bar) and too low a fuel flow in total. 1500cc /30 sec.
So I am fitting a 2nd 044 Bosch pump - ie one each front and rear. Then I will tune/balance the FD.
Happy to post that stuff if that is what is wanted. The 'tuning' - AFRs - I do on the track - via the WUR pressures. I have mine so I can adjust it in situ, and have a permanent pressure gauge on the WUR.
Alan
Pat RUFBTR 03-15-2021 10:59 AM
I’m having a little trouble understanding your explanations in English, so if I could get some pictures, it would help me understand. thanks you Alan L ! :)
Alan L 03-15-2021 07:33 PM
Hopefully the pics will explain.
When you see the calibration data, the first run is as the fuel head delivered after reassembly.
To recap - my car had been sitting about 6 mths. Been running fine. Would not start - fuel problems. Front 044 pump (near new) had seized. replaced. Week later the new 044 seized. Had small amt of very fine grit on the pump intake screen. Spent some time cleaning swirl pot in tank as best I could without cutting the tank. Very little in there basically and tank interior fine. Install another new 044 pump. Now the injectors are squirting constantly. Metering piston seized in FD. Could not free it - had to split the FD. Maybe a magnet would have pulled it free - it wasn't badly stuck. But now I have to recal the FD.
Check fuel system prior - low flow at FD (1000cc/30 sec.). I had more previously. Check pump pressure differential - 5.5 bar. Too high - spec is between 2-4 bar. Either filter blocked or rear pump substandard. Replace filter. Differential now 5 bar. Pump must be suspect. Replace with another new 044 - now got 044 front and rear. Differential now 2.5 bar. Looking better. Check flow - 1700cc/30 sec. Enough. Now set system pressure. 6.5Bar +/-. Now ready to do injector calibration.
I concentrated on #6 which was low, first, then went to #1. You could do both at same time. Then I convinced myself to crack open #2 for a small adjustment at the end.
You need a weird allen key size (9/64) to open the adjuster port - remove the black sealing cap. You use your idle adjust allen key (3mm) to tweek the adjuster port.
I am for even number from 1-6 - but you could easily bump 2&5 up by say 5% by this process. Unwind the adjuster port to reduce flow at that injector and vice versa.
I had explanaotory captions on the pics - which didn't come out.
#1 you need plenty of space
#2 checking the pump differential press - I just took the pic since I was in there.
#3 measuring flow rate
#4 collecting the injector flow
#5 I measure mine in a measuring cylinder
#6 - getting ready to adjust - remove the cap over the adjuster port
#7 doing an adjustment
I use an outside power source to power the pumps when doing this - jumper leads off a running motor. The pumps suck a lot of power.
Alanhttp://forums.pelicanparts.com/uploa...1615861767.jpg
Alan L 03-15-2021 07:44 PM
Forgot to post calibration figures.
Alanhttp://forums.pelicanparts.com/uploa...1615862624.jpg
gsxrken 03-16-2021 06:42 AM
Alan, excellent post. Two questions - did you by any chance check your flow with the air plate pushed down to simulate something other than idle? Always been curious to see if it’s any different.
Other thing is do you know what names/sizes of the adapters you used at the rear pump to fit the gauge temporarily and check your pump differentials? I want to do that but don’t know what to ask for at the parts counter.
Thanks!
Alan L 03-16-2021 11:32 AM
To check the flow, you need the injectors shut. To compare apples with apples - factory values/specs. Any flow thru the injectors will detract from the flow values (unles you collect them as well). This is the port for the return line to the tank. Anything not going to the tank (injectors) will screw the number.
I have measured the flow at the injectors at WOT and get just over 1000cc/30 sec.
So at factory value of 1500/30 sec - minimum, you have 500 cc/30 sec returning to tank.
My differential pressure thing is a home made cobbled thing - and I have the same issue as per fittings.
But the critical fitting is the one that hooks on to the fuel fitting at the end of the front pump line. - Mine came off the discarded fuel filter. It has a couple of fittings screwed in it - as it comes out of the box. One of them happens to be what you want.
Then I just cobbled what brass fittings I had that would fit.
If you grab the filter fitting (ball socket type fitting with a thread on the other end) (can post a pic), and take your pressure gauge - then the shop should be able to assemble enough bits for you to Tee the gauge in.
Regards
Alan
Alan L 03-16-2021 12:59 PM
This is your critical fitting. The ball socket end connects to the front pump supply line. There is one of these at the intake side of your rear pump. So with that fitting you can cobble enough bits together at your supply shop.
Alan
http://forums.pelicanparts.com/uploa...1615924697.jpg
Alan L 03-16-2021 05:37 PM
OK - the thread with the non- socket end (inserted in the fuel filter) is M14x1.5.
The socket end (that fits to the front pump supply line) my best guess is M16x1.5. The 1.5 is right and I am picking M16 as right. So if you take the spare one off a dead fuel filter - or obtain one from a supply shop, the socket bit goes on the fuel line from front pump. That leaves you with a M14x1.5 male thread to attach your gauge Tee piece plumbing to. Then your hose end at the rear pump end needs to attach over the M16 (?)x1.5 male socket fitting. I didn't have anything with a socket ball fitting - I just found a brass fitting with the same thread (female) M16x1.5 at a guess. So not a perfect seal - slight leakage around the threads - but close enough.
So to get back to the original point of the post on 2/5 lean, if I was getting say even 50 (cc) flows over my balanced FD and wanted more on 2/5 I would be looking to bump them up as far as to 60 while the others read 50. Somewhere between 55-60 would be my guess. 55 is only 10% more. Those 2/5 look real lean. At worst, you would be slightly rich on 2/5 by going 20% more. But my SC manual tolerates a 10% variance in the FD flows - ie within 10%, don't need to adjust anymore. I think you are looking for something a bit more than 10% to correct the issue.
Regards
Alan
Alan L 03-16-2021 06:00 PM
OK - tried to edit - but can't. Can confirm M14x1.5 for one end and M16x1.5 at socket end.
Alan
heliolps2 03-16-2021 08:14 PM
Regards
Alan
Hi Alan, and Turbo friends
Great write up, It maybe a little complex for some people to follow. I went through the complete system and balanced the fuel rates like you just did back in 2011-12 on my yellow 3.3 turbo. It's a lot of work but worth it to understand how the fuel system works. After all that I still ended up lean on 2 and 5, the only way to know for sure was pulling the exhaust off and get a visual, I ended up turning the adjuster on the FD about 20deg of a turn to get a balanced color through out the exhaust and even exhaust temps.
On my 965 I did not go through all the testing and balancing this time around, because my issue was exactly issue I had before on the yellow car, lean on cyl 2 and 5. I simply skipped all that and just adjusted 2 and 5 at the FD about 20deg of a turn, I hope that should be good The only to know for sure is to pull exhaust and get visual. That's my next step in a couple of weeks. It should pretty simple since everything is fresh.
Stay tuned.
Helio
heliolps2 03-16-2021 08:21 PM
Alan,
How many deg of a turn would you say would be 10% or 20% more fuel. 360deg being a full turn of course. Also when you added fuel to, lets say #6, would the fuel rate go up or down on all the other injectors? from your chart they seem to have gone up as well. Please explain what was your proses was from adjusting 6 to 1 and then 2, looks like you were chasing numbers for a while ?
Alan L 03-16-2021 10:11 PM
I was adjusting about 1/4 turn each time. Bear in mind I had just reassembled the FD from raw components on my bench. That is why I just concentrated on #6 to start. The FD had a new gasket and I expected it may take a bit of fuel flow for it to settle reliably. I was also chasing some small weeping around the injector line fittings on the FD. It all took a few runs to sort things out.
I was happy to do a few more runs than needed to make sure it was going to stabilise.
At a guess I would say 1/4 turn was giving me between around 5%.
It makes no difference to the other readings - unless the FD is maxed out - or you are not supplying enough fuel (low flow rate). You can see the 3,4'5 readings were pretty stable right thru. Never touched them.
My FD is modded for more flow but I am still near the edge of max flow for it. Which is why I looked for repeat runs showing some stability.
Given the fact this is a turbo engine and AFRs are important, personally I would not trust it just to tweek a couple of injector ports without checking. At least check the plugs sometime soon after - but I prefer to rely on calibration numbers. My engine gets a hard time, and so far never had an issue with meltdown or detonation.
Regards
Alan
Pat RUFBTR 03-17-2021 11:23 AM
Thanks a lot Alan L, great! :)
heliolps2 03-17-2021 04:46 PM
Thank you Alan, Great to hear that a 1/4 turn gained you 5% more fuel, I only adjusted mine 1/8 of a turn, which shouldn't harm anything, but after checking the plugs as you suggested and or pulling the exhaust, I may have to give it more fuel. Thank you for the follow up friend.
Helio
Alan L 03-21-2021 10:36 PM
I would say between 5-10% more fuel at 1/4 turn. Not exact - because I wasn't really measuring those parameters. But that would be ball park numbers. As long as you are adjusting the right way - you should be safe without calibration runs.
The problem is you can't just check 2&5. You will flood the other cylinders. (I just drained the oil because of my earlier metering piston problem - pouring fuel in). Annoying - but honestly - I would say 2-3 hrs max to tear down (remove IC etc) and do a proper calibration. Most of us even busy, can find half a day sometime - too windy/rainy /cold etc to go outside. A half day well spent.
Alan
heliolps2 03-31-2021 07:50 PM
Hey all,
Update on the lean cly 2 and 5* issue, Yesterday I went for a 250 mile road trip to see my 13 year old son an daughter for dinner, My son drove her for 30 min on county back roads and he even got on the boost in second and a little in third gear. That's my boy. Anyway , drove straight home and parked it, that's important because I wanted the engine nice and hot from they long hwy drive home before turning her off, Because I wanted to pull the exhaust and check exhaust ports color on the heat exchangers and this what I found. By the way, start to finish it took one hour and half. It went very smooth. Yay! I think I added just the right amount of fuel to 2 and 5, They look pretty balanced compared to before. 2 and 5 were white as paper before. Way too lean. I knew of this issue with air cooled 3.3 and 3.6 turbo engines, from past experience with my old 3.3 turbo 911, Simple fix. I'll check my AFR's on tomorrow. I hope this helps you guys.
http://forums.pelicanparts.com/uploa...1617245267.jpg
heliolps2 03-31-2021 07:51 PM
The before pic,http://forums.pelicanparts.com/uploa...1617245484.jpg
heliolps2 03-31-2021 07:53 PM
http://forums.pelicanparts.com/uploa...1617245543.jpg
heliolps2 04-05-2021 03:12 PM
What are your thoughts on the exhaust color? Please remember I was using a flash when taking the pictures, so it looks a little lighter in pictures. I still need to check my AFR's, a friend is using my Innovative handheld unit on his 930.
Gianni at Pelican Parts 04-05-2021 04:00 PM
Great post and documentation Alan L! Thank you for sharing this valuable information with the community
Alan L 04-06-2021 12:32 AM
Gianni, you and others are welcome. That's what the forum is for. So much valuable info shared.
Happy to pay back some.
Alan
heliolps2 04-06-2021 08:22 AM
Alan
You are welcome, I'm happy to help the cause, Alan thank you as well, what do you think of the color on the exhaust?
Alan L 04-06-2021 11:42 AM
The exhaust looks good - not the easiest telling from pics. But looks quite even.
Regards
Alan
heliolps2 04-07-2021 02:06 PM
Here's a closer look at it before
http://forums.pelicanparts.com/uploa...1617829567.jpg
heliolps2 04-27-2021 12:07 PM
After adjusting the fuel head, It seemed to be a little rich at idle as expected. I finally got my handheld Innovate LM-2 ARF tester back, not surprisingly my Idle afr's was rich, at 12.3 with the air pump and Co2 sensor disconnected. I have no cat. It was simple to adjust the afr's to 14.1, with everything still disconnected. Once I connected the air pump and Co2 sensor a solid 14.7 and made a minor idle adjustment to 1000 rpm's, all good. No drama. Win!
heliolps2 04-28-2021 02:12 PM
Here's another update using an Innovate LM-2. I would like to see a little less fuel on top, but I'll take.
http://forums.pelicanparts.com/uploa...1619644186.jpg
