1979 930 @outlaw3.4
Let’s talk about spark plugs
Maybe I am not searching correctly, but not finding much on the topic of forces induction and spark plugs.
What are people using and why? I have Bosch F3CS / NGK BREIX9 The F3CS eem to be discontinued
1979 930 3.4l Peter Dawe Motor, Bosch Twin Plug, Dual Bosch CDI, J&S Ignition Control, Webcam 158 , Maxed Flowtech Fuel Head, BL Adj WUR, Braided Fuel Lines, 009 Injectors, GT35R, TIAL .7with Turbosmart MBC, Fabspeed Long Neck IC, Fabspeed Headers, GT3 Style Pipe off turbo, Rennshift Short Shift, KEP Clutch Package, 8.41, Elephant Racing Suspension, Weltmeister Sway Bars, ??WHP, Innovate MTS Gauges, RPM, Switch,SplitSecondAIC 7th |
I’m using Bosch plugs. I’m curious if anyone is using the Bosch motor sport plugs. I hear they are good for more hp. Also is anyone indexing their plugs? Sorry don’t want to hijack the post but this might add to the conversation..
I am using Bosch W3DPO on the top side and NGK D8EA on the bottom.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
I use BR8EIX on top and DR8EIX on bottom. I replaced them last year for the first time since I finished my engine build 12 years ago.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I use Bosch w3cs on the 3.5 twin plug, and W4cs on the modified 3.3 single plug.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
I was running W3DPO's on the top and NGK on the bottom in a twin plug set up. I switched to NGK in all 12 and haven't had any issues. I've used NGK in several vehicles/motorcycles over the years and have been happy with their performance. I change them 1-2 times a year depending on how much I've driven it or when the mood hits me. I don't know the exact part numbers but can get them tonight if needed.
3.4,K27,Andial IC,Sc cams,Ported heads,Electromotive Ign,Twin plug,Leask Wur,RarlyL8 zork,GHL headers,Simplified CIS,Ported fuel head,Fikse wheels,Etc.Go hard or go home |
I've recently switched to NGK BKR8EIX, top and bottom, with good results. These also have a smaller hex diameter and makes using a standard spark plug socket easier.
1979 930 @outlaw3.4
Looks like most of you all are using # 8 heat range plug.
Seems to be that compression / timing / boost / fuel / all contribute to plug heat range....so I want to stay oin range with what the builder put in. B F3CS / DR9EIX The disc Bosch F3CS is apparently a high performance colder plug for WOT. I may need to widen my search to get more options...
1979 930 3.4l Peter Dawe Motor, Bosch Twin Plug, Dual Bosch CDI, J&S Ignition Control, Webcam 158 , Maxed Flowtech Fuel Head, BL Adj WUR, Braided Fuel Lines, 009 Injectors, GT35R, TIAL .7with Turbosmart MBC, Fabspeed Long Neck IC, Fabspeed Headers, GT3 Style Pipe off turbo, Rennshift Short Shift, KEP Clutch Package, 8.41, Elephant Racing Suspension, Weltmeister Sway Bars, ??WHP, Innovate MTS Gauges, RPM, Switch,SplitSecondAIC 7th Last edited by MZ3 SBC; 03-31-2021 at 08:21 AM.. |
NKG bkr8eix for years on top and bottom for years with no blow out problems on e-85 and 93 octane
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp |
Denso IK24 or NGK BKR8EIX for applications with 14mm threads.
No problems. Rarely run the W3DPO on stock applications, almost always run one heat range warmer, as was done on the 1991-92 964 Turbo. 99% of the cars do not see Autobahn style driving with extended periods under load and high temps. Instead, there's much more stop-and-go, and consequently plug fouling, thus the move to one step warmer plugs.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
1979 930 @outlaw3.4
Looks like the Heat Range 8 / Bosch 4 FTW. I dont think I get to run hard enough long enough to keep the colder plugs clean. As always so much good reading and threads to be read on Pelican.
I was curious why some write BKR8EIX and while i was talking BR8EIX I looked up the part numbers and there are 3 different terminal types... and with NGK its ...Solid Cap:BKR8EIX and Removeable Cap: BR8EIX and the studded no Cap: CR8EIX So much for the good ole Copper Top days....everything is simply complicated Thanks all for the contributions to what is another plug discussion.... ![]()
NGK BR requires taking the aluminum screw on cap off your old plug if you don’t have resistor plug caps.
The BKR8EIX no longer has a removeable terminal nut.
Why manufacturers have discontinued this feature, we do not know, cannot get an answer from them.
What's the deal with Bosch W-3-DPO prices - $37 a piece?
I like to use original equipment, but gee whiz!
1986 911 turbo - less than 30k miles |
