Need Advice on CCW Wheels
Well, due to a near total unavailability of anything other than R compounds in fat rear tire sizes... Looks like my 16 inch period BBS RS's are gonna get put on a shelf.
So Now I am in the market for some new CCW's, and unless anyone has some Classics with 930 fitment in either 17 or 18 inch (and if you do, drop me a PM), I am very partial to the LM20. Is anyone running the LM20 on a 930? If so I'd love to see some pictures of your fitment with any details you may have. and onto the great debate: Do I go with 17's which look PERFECT on these cars, knowing I have limited tire sizes and future unavailability. Or go 18, knowing they look a little silly, but I am spoiled for choice on tires. Post pics of your 17 or 18 inch setups to help me choose, or even a 17 front / 18 rear combo. I am open to everything. Some pics of my current setup..... Last edited by Groovie Ghoulie; 04-20-2021 at 05:13 PM.. |
Driver
Here's a pic someone else took of my car at one of the Luft events. 17" Fikse Fuchs.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Had ccw classics on mine and it had a great 934 look about it! Loved them but sold for fuchs now on rufs. Def 17s look the best!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Here are mine--17X9 and 17X11 Fikse FM10. You can find them here in the FS section from time to time. Way better than CCWs.
I have two sets, CCW and Braid BZ. Love them both for different reasons. Both sets are 17x9 & 17x11.5, running 255/40 and 315/35 tires. 18s just don't look right on these cars, in my opinion, but sadly we may have to end up there eventually due to future tire availability. G bodies with 17s look ok, early turbos look really good with super-wide 15s.
![]() ![]() ![]() ![]() ![]() Rey's incredible early turbo:
Garen GNdesignLLC.com - Automotive Art & Sculpture |
^^^ both sets of ccw and braids look awesome! then of course the 15s with cubby rubber on Reys look so goooood too!
Thanks man. You car looks really good with the Ruf wheels you're running now. It's perfect.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
I like my CCW's with 2 sets for the Hoosiers and one set of Fikse for the wets.
Another style 17" Fikse forged wheels to consider for a 930. From last time I looked I think 9" fronts and 13" rears.
Anthony @ Voitureltd Bayside WI. Last edited by voitureltd; 04-22-2021 at 11:35 AM.. |
Driver
CCW are not forged?
If memory serves, I think the CCW centers are forged, and the lips are spun. The extra holes mean the center is a "comp" model, and are intended as a lightening measure. They are not there to accommodate other bolt patterns. If you compare the wheels in my post to the ones on Jacob's car, you can see the street (mine) vs the competition (his). The street version also had a choice for a center cap, whereas the comp model did not. At the time, my car was much more civilized, which is why I went the street route. Would've ordered the comp version if I knew where the car would be headed in the coming years.
Another difference is the inner, outer, and center on the CCWs are joined by a bolt and a nut (through hole), whereas the Fikses have hidden hardware. Not sure if the bolts holding the halves and the center together directly screw into the aluminum on the Fikse, or if there is a more robust insert. I have never taken one apart. Both brands have been used in racing, on OE teams as well as pro-level privateers, so there is enough data that they hold up to the stresses of hard track use. The main reason I went with the CCW back in the day was that John (he owned CCW at the time) was awesome and easy to deal with, with great pricing and turnaround. He kept his overhead low and passed the savings onto his customers. The reason I also have the BZs is because Paul (he IS Braid USA) is a friend, and local to me, and we used my car and a friend's '77 930 to work out the initial offsets for the BZ 17 prototype. Good times. To me, the CCW, Braid, Fikse, and the Ruf all look great on the 930. The Fikse has a more "finished" look compared to the CCW, as it has some neat design details on the center. For sure, the extra CNC mill time is why there was a substantial price delta between them and the CCWs. Rufs were just as expensive and unattainable then as they are now (relatively speaking).
Your car is what inspired me on the CCW website actually. What tires are running in 315x17? |
Cool!!! That was back when it looked nice and clean! The shots with the CCW were taken just about the next day from getting the wheels, the tires were Kumho Victoracers (which are NLA). I switched to Nitto NT-01s after that. When I get the car back on the road again, the CCWs will likely get Hoosiers, and the Braids will run on NT-01s. As for availability of other brands, I am not sure. I think Nitto runs their NT-05 as well as the NT555 in a 315x17, Goodyear had an Eagle in that size, and Toyo makes a 315x17 in the R888, I think; but not sure of any other brands. Check TireRack, I'm not too current on what is out there.
I have an unmounted set of Goodyear Eagles that are just over 10 years old, but were stored out of the sun in a non-damp basement. Not sure if they need to be booted in the trash or if they are OK to use given their age. They are soft and pliable like a new tire. edit: I didn't realize these shots were still on the CCW site!!! They got their money's worth, I took these on the rooftop level of a hotel parking lot near me.
Garen GNdesignLLC.com - Automotive Art & Sculpture Last edited by Garen; 04-22-2021 at 04:42 PM.. Reason: added lines |
I hope 17" BBS LMs are okay?
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
I stand corrected on my criticism of the CCWs. Thanks for setting me straight.
![]() Fikse 18x9&11 Very happy with the look and performance and the tire choices of the 18’s
Tim 87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost.... Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims. |
