-   -   Alternator Upgrade 76 Turbo (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1093359-alternator-upgrade-76-turbo.html)
Les Paul 05-13-2021 03:47 PM
After owning my car for 36 years I am nervous as hell trusting the original alternator. Every other moving part on the car has been replaced. Mine has never given any clue that it could go but? Our host sells multiple alternators. Has anyone here added the higher output units? Also, adding back Ac after deleting it 34 years ago. Moving to south Florida soon so it becomes necessary.
RarlyL8 05-13-2021 05:33 PM
I've never had any luck with "new" alternators. All Asian junk. Hopefully someone has a lead on where to get the good stuff.
Alan L 05-13-2021 10:26 PM
There is a high output version which has been referred to on other threads.
Maybe a bit of a search in the 911 Tech forum will find it.
You could always get your alternator rebuilt. Bearings, brushes new VR.
Alan
speednme1 05-14-2021 06:58 PM
Classic Retrofit may have what you’re looking for Les
Les Paul 05-14-2021 07:31 PM
Is it Asian junk or made where?
JacobS911 05-17-2021 08:55 AM
Just got my classic retrofit ac with high output alternator. They use alternators from the company below.
Alternators - WOSPerformance
pkabush 05-17-2021 10:58 AM
Several years ago, Jim Fairman posted a link to a eBay seller who sells high output alternators for our cars. He seamed quite happy with it. I ordered one and it definitely looks high quality but doesn’t fit my housing. Jim’s 930 was a 86 and mines a 81. Not sure if that’s why but I’ve read about people having to machine the housing down. 13.8mm if I remember correctly.
gumba 05-17-2021 11:27 AM
Is there a part number from WOSPerformance alternator that is a direct fit for the '76 930?
JacobS911 05-17-2021 12:22 PM
Yes, you will need a LMA036 according to the wosp site below (but looks like 70amp rather than the 175amp one I just got through classic).. You'll need a adaptor ring from classic or custom made on your end locally. Links for the adaptor and full alternator below.
200 Series Alternators - WOSPerformance
https://www.classicretrofit.com/collections/upgraded-alternators/products/upgraded-alternator-adapter-1974-1983
https://www.classicretrofit.com/collections/upgraded-alternators/products/copy-of-porsche-911-high-output-175a-alternator
Jonny H 05-25-2021 01:24 PM
The 175A alternator is a joint development between Wosp and Classic Retrofit. It is based on modern Denso internals inside a custom billet case. 100% U.K. manufactured.
If you want a bit more insight into the development, I made this video.
https://youtu.be/P9dy5wSbeHk
Les Paul 05-26-2021 12:32 PM
Thanks got one on order
