Alternator Upgrade 76 Turbo
After owning my car for 36 years I am nervous as hell trusting the original alternator. Every other moving part on the car has been replaced. Mine has never given any clue that it could go but? Our host sells multiple alternators. Has anyone here added the higher output units? Also, adding back Ac after deleting it 34 years ago. Moving to south Florida soon so it becomes necessary.
63 356 So Called Outlaw
76 930
Old 05-13-2021, 03:47 PM
Crotchety Old Bastard
RarlyL8's Avatar
I've never had any luck with "new" alternators. All Asian junk. Hopefully someone has a lead on where to get the good stuff.
Old 05-13-2021, 05:33 PM
Alan L's Avatar
There is a high output version which has been referred to on other threads.
Maybe a bit of a search in the 911 Tech forum will find it.
You could always get your alternator rebuilt. Bearings, brushes new VR.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-13-2021, 10:26 PM
speednme1's Avatar
Classic Retrofit may have what you’re looking for Les
Rey....77 930 "the Mistress"
Old 05-14-2021, 06:58 PM
Is it Asian junk or made where?
76 930
Old 05-14-2021, 07:31 PM
Just got my classic retrofit ac with high output alternator. They use alternators from the company below.
Alternators - WOSPerformance
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 05-17-2021, 08:55 AM
Several years ago, Jim Fairman posted a link to a eBay seller who sells high output alternators for our cars. He seamed quite happy with it. I ordered one and it definitely looks high quality but doesn’t fit my housing. Jim’s 930 was a 86 and mines a 81. Not sure if that’s why but I’ve read about people having to machine the housing down. 13.8mm if I remember correctly.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 05-17-2021, 10:58 AM
gumba's Avatar
Is there a part number from WOSPerformance alternator that is a direct fit for the '76 930?
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 05-17-2021, 11:27 AM
Yes, you will need a LMA036 according to the wosp site below (but looks like 70amp rather than the 175amp one I just got through classic).. You'll need a adaptor ring from classic or custom made on your end locally. Links for the adaptor and full alternator below.
200 Series Alternators - WOSPerformance
https://www.classicretrofit.com/collections/upgraded-alternators/products/upgraded-alternator-adapter-1974-1983
https://www.classicretrofit.com/collections/upgraded-alternators/products/copy-of-porsche-911-high-output-175a-alternator
Old 05-17-2021, 12:22 PM
Jonny H's Avatar
The 175A alternator is a joint development between Wosp and Classic Retrofit. It is based on modern Denso internals inside a custom billet case. 100% U.K. manufactured.
If you want a bit more insight into the development, I made this video.
https://youtu.be/P9dy5wSbeHk
Old 05-25-2021, 01:24 PM
Thanks got one on order
76 930
Old 05-26-2021, 12:32 PM
