An other 930 bouncing tachometer
I am new to this forum and I read a lot of comments about what causes a tachometer to bounce. On my car, the problem is clearly related to engine heat. Each time the engine heat needle passes the first white line, the tachometer starts bouncing and stops. It will come back alive as soon as the engine temperature falls below that critical level.
To solve the issue, I first sent the tach to North Hollywood and they sent it back mentionning that it was working well. Next, we changed the CD box. No change. Then, we changed the voltage regulator and the wiring behind the alternator and the fan. Same result.
I really dont know what to do next.
Any suggestion ?
Thanks a lot for your help.
Old 08-23-2021, 03:00 PM
Remove the 14 pin connector at the rear of the three fuse panel, clean any corrosion from the pins and reinstall. See if that helps.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 08-27-2021, 08:51 AM
Super !
Old 08-27-2021, 06:48 PM
Groovie Ghoulie's Avatar
Mine did this when the CDI box was about to die! as the car got hot the CDI box would start acting up. When it goes, it goes. car will be dead on the side of the road!
You can get it rebuilt by ecudoctors with a 5 year warranty for about 500 bucks.
Old 08-30-2021, 05:13 PM
If you have big money you can get a more modern unit from classic retrofit
https://www.classicretrofit.com/collections/cdi-ignition/products/911-cdi-6-pin?fbclid=IwAR0K_UxTmHqVC-9Nvely6t2_Np9zS3_UHTdR21R8JQmoBvW-hKQaTy3i0bo
Old 08-30-2021, 05:15 PM
Or you can buy the stock 930 cdi I have on the shelf lol. I also have two coils, a distributor and most of a harness
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 09-01-2021, 09:58 AM
Mine (tach fluctuating) was due to faulty Alt years ago....
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 09-03-2021, 07:59 AM
Same here. A dying battery or a bad alternator will cause your tach needle to bounce. If you put a volt meter on your battery and have someone rev the motor you should see the voltage go up to around 14V. If the volt meter doesn’t move when the engine is revved than your alternator is faulty.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 09-03-2021, 09:42 AM
Same for me. I had to pull a remaned Bosh alt and have it gone thru. From some research I don't think I am alone with a reman Bosh going bad early....
Old 09-08-2021, 08:02 AM
had a bouncing tach recently as well.. turned out to be lose connection on the ground terminal of my battery.. hopefully something as simple as that on your end!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 09-12-2021, 01:38 PM
So I guess I jinxed myself, as mine started fluctuating again, as well as just hanging at 5K. Turns out my battery was going bad, reading 10 volts when charged, and finally just completely died. Replaced it and tach is now normal, with good battery voltage.
Tim
1986 930
Old 09-15-2021, 01:27 PM
Bouncing returned , although in a much more limited form. Never a problem at idle, and only after driving car for 30-45min, then it would just hang at around 2500-3500 or head straight up to 5-6 and remain. My guess is the Alt was sending spikes when hot. It’s been 15years and over 100k so I just went ahead and replaced, this time with new Valeo. Last time was new Bosch. Also gave me a chance to clean up engine bay.
Tim
1986 930
Old 09-28-2021, 05:36 AM
Check Speed relay
There is a remote chance that If your 930 is running the emissions from 86-89 with Speed relay under the drivers seat, when this malfunctions it can destroy the tach signal at the CDI box. Most 911's run directly between the CDI box and tach. The emissions 930 also runs a signal wire to the speed relay.
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 10-09-2021, 10:49 AM
