EFI for sale
Not sure if for sale posts are allowed here?
After changing to a new EFI with all the bells and whistles modern ECUs have, I would love the se my old set up live on in someone else's car. It is an old EFI Euro 96 system, but it worked fine on my car, and is probably a lot better than the original EMS. I made 530WHP with a BW S366
This set up comes with ECU, trigger wheel and wiring harness. It also comes with the very expensive CAN to USB module you need to connect to the ECU (not in the pictures).
I would think this is a perfect starting point for a low budget DIY. Note that the Tach did not work when it was removed. I later found out my tach was broken, but since I cannot validate that the RPM output works, it will be sold with a none working RPM output.
Price $600/obo shipped world wide
For an extra $150 I can add PLX MAP and wideband, with display. These have 0-5V output, and can be used with the ECU
Old 10-17-2021, 11:12 AM
