WUR leaking Fuel
Hello all,
My friend (co-owner of my 930) is on a trip with our 930 and found the WUR leaking fuel from the orange gasket of the body. The only way fuel pass into WUR body is a ruptured diaphragm of diaphragm seal... Have you guys ever encoutered this situation ? Thanks Arnaud
Many projects on the way... 1987 930 Road trip car (1/2 owned) 1982 DP935 future beast 1969 911T rust bucket 1966 911 Buffum college car (1/2 owned) |
Crotchety Old Bastard
Diaphragm can rupture with age or excess boost. The OE diaphragm is not rated for pressure above 1.0bar.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Yep.
When I purchased my adjustable WUR from Brian Leask, he advised I go with “the heavy duty diaphragm option” if I intended to boost beyond stock levels. If your friend is on a road trip, you should try to find someone with one in stock that they can overnight to him where he’s stuck. Leask’s turnaround time, and the tuning you’d need to do with it, don’t lend themselves to a roadside swap scenario. Call Brian (the poster just above this one) to check stock. Good luck.
Ken 1986 930 2016 R1200RS |
Fortunately, the car could be stored where the problem happend and I have few NOS WUR in stock (in another city) so we'll go next week to fix it...
The failed WUR was a BL one with the HD diaphragm. However, to me the diaphragm on boost side cannot be the culprit, the fuel should be contained into the upper part (steel) of the WUR. If I understood well how WUR are built, either the steel diaphragm has rusted out or its O-ring suffered from age.
1979 930 @outlaw3.4
I am in the process changing out my WUR> standing at the front door waiting for FED EX shipment from Brian like a faithful pup!!
I get what you are saying....the video is not very helpful. I assume you have the stock airbox ? if the WUR was leaking it SHOULD be from the line in , line out or the breather which would go to stock airbox or vent to atmospher / down a hose if thats how you set up. Mine vomitted fuel out the breather. If its the WUR... leaking those are the only places. - is the fuel pooling there butdripping down a fuel line or out of air box? - car sounds like its stumbling from being too rich...one of the indications of aWUR failure. I am no expert...just sharing my experience....If it wur me ......I would disconnect the hose on the breather and see ....I would also look to the fuel line from fuel distributor ... be sure to update us ...good luck
1979 930 3.4l Peter Dawe Motor, Bosch Twin Plug, Dual Bosch CDI, J&S Ignition Control, Webcam 158 , Maxed Flowtech Fuel Head, BL Adj WUR, Braided Fuel Lines, 009 Injectors, GT35R, TIAL .7with Turbosmart MBC, Fabspeed Long Neck IC, Fabspeed Headers, GT3 Style Pipe off turbo, Rennshift Short Shift, KEP Clutch Package, 8.41, Elephant Racing Suspension, Weltmeister Sway Bars, ??WHP, Innovate MTS Gauges, RPM, Switch,SplitSecondAIC 7th |
![]() So, here’s the culprit. The steel diaphragm in the fuel pressure regulation part of the WUR. Now, have to find the root cause.
Still here
Congrats on dodging a bullet there, the fuel was pooling !
