-   -   Seal for air valve housing difficult to replace? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1104662-seal-air-valve-housing-difficult-replace.html)
TDH888 10-17-2021 07:13 PM
Hi guys ,
Finally my 89 930 is & finally reliable after a couple of issues were solved / fixed . Loosing power at 4000 rpm was because of wrong routing of the vacuum hoses , melting fuel pump relays and 25 amp fuse , the big macaroni shaped hose was also replaced . Yellow relay for air flow sensor was likewise replaced . Ignition wire from the ignition coil to distributor was likewise replaced . And finally my CDI box was repaired and w/ parts upgraded w/ the help of pelican parts forum . The car now runs better than before except for the metallic sound that I hear occasionally . After researching the forum this part needs to be replaced . Is this part hard to replaced or to work at . It’s part no. 7 in the diagram and the parts are available from our host.
http://forums.pelicanparts.com/uploa...1634526567.jpg
http://forums.pelicanparts.com/uploa...1634526766.jpg
356911930 10-17-2021 08:04 PM
As I recall, the front seal (front being the front of the car) is not easy to remove with out removing the whole valve housing. The rear seal is not to difficult IIRC.
Rahl
TDH888 10-18-2021 02:24 AM
Thank you Rahl for your reply is the valve housing difficult to remove to acces the front part ? Thanks in advance
DaytonaCoupe66 10-18-2021 03:03 AM
Replacing these seals is a simple task if you remove the valve housing. The housing is a straight forward removal. You can also inspect your O rings and replace if necessary.
The large hoses on the left side can be a challenge to put back on. Take your time and you'll be fine. There are threads on pelican that describe the process with great photos.
donbecker1234 10-18-2021 04:10 AM
IIRC the spring (#4 in the diagram) is available as well. I replaced mine when I replaced the seals since I was already there.
pkabush 10-18-2021 01:20 PM
Or you could mothball the air diverter and convert to a long neck inner cooler
:cool:
TDH888 10-18-2021 08:13 PM
Thanks you very much for your replies and tips , I ordered the part already
full quack 10-22-2021 02:09 AM
Simply FYI, those end caps are under a fair bit of tension, due to the compressed internal spring. If you are not careful while doing the disassembly, you will be in for an unwelcomed surprise.
For removing the first end cap, leave 2 screws in place (180 degrees apart) by 2 or 3 threads, then firmly hold the end cap in place while you remove those 2 screws, release pressure on the end cap slowly as the spring pushes against it.
Mark
1Bad86 10-22-2021 10:55 AM
I replaced mine a few years ago and it really wasn't that difficult compared to a few other tasks. I'll be doing a long neck conversion this winter using this piece for parts.
TDH888 10-22-2021 10:20 PM
Thanks for the tip full quack . I will ask my mechanic to be careful . And follow your advice
