Boost pressure sending unit - thread size?
Hi guys, since installing a mechanical gauge, I sold my electric gauge and sensor (not an original 930 car, so non-original).
I was planning to remove both this weekend but was hoping to have a plug ready to stick back in the intercooler in advance. Any idea what the thread size might be for the sending unit? Thanks in advance!
Old 08-22-2023, 07:16 AM
mark houghton's Avatar
Nope. Just take it with you to your local store and match up the threads.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 08-22-2023, 12:27 PM
Thanks, Mark - that was backup plan. After reflecting on multiple hardware store trips mid- DIY home improvement project, I was hoping to avoid. This seems east enough though (famous last words?)
Old 08-23-2023, 06:31 PM
I think I have one in the garage, ill check it tonight and let you know.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 08-23-2023, 10:07 PM
81 930's Avatar
M18 x 1.5
Brian
1981 930
Old 08-25-2023, 10:44 AM
Awesome - thanks, guys! I was an hour away from heading home to get to work.
Edit - an o2 sensor plug works perfect for this. Thanks, Brian!
Old 08-25-2023, 11:04 AM
This is a timely thread for me. My 964T intercooler has some beat up threads at that opening.
So, I need to buy an appropriate sided thread chaser. I just tried to match it up but neither HD
or Lowes has the correct sized thread gauge. Biggest they go is M14. I actually thought the size was M16x1.5 so thanks for the info. Hopefully I can get it to hold pressure. If not, my thought is to smear some JB weld on the threads. If that or the thread chaser don’t work I’ll look into a Time Cert
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 08-26-2023, 10:59 AM
81 930's Avatar
Glad I could help. As sigchuck stated, it's the same thread size as an O2 sensor. An O2 sensor thread chaser will work fine for cleaning up the threads...provided your threads aren't too buggered up.
Brian
1981 930
Old 08-26-2023, 11:14 AM
Old 08-26-2023, 11:37 AM
