Should I Cut access hole for crank pulley
Should I cut a access hole for my crank pulley like the motor on the cover wane Dempsey book. Or will that allow excessive heat into the engine compartment . From the turbo? I hate not being able to turn the motor by hand. Can't access the crank bolt.
It's a 914 ...
I find it convenient to put a socket on the pulley bolt through a hole in the console to turn over the engine.
perfect i hole it will be .... DSM that's a great picture bad ass.
use the ALT bolt and press on the fan belt to keep it from slipping
I think right side.
yes
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Banned
great to see CT'ers here... let's aim to meet come spring and trade stories 8 )
