case trans stud length for starter
I need to know the total length of the stud that connects the top of the starter to the transmission and the engine case .. The one with the 10mm Allen nut .. my car currently had a bolt and i would like to replace it with the correct stud . i made the mistake of putting it in the car before i replaced it , so trial and error is not an option.
I searched some old threads and find conflicting information and the links provided are no longer good. Thanks in advance Regards Ned |
Ned, I’m pretty sure it is M10 X 115mm. Unfortunately I am not 100% sure so you will need to double check.
Best of luck, Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
I removed this from a old 2.7l case I forgot I had 122mm
